> Interior keeps fogging up!
post Dec 30, 2011 - 1:20 AM
block
Joined Jul 27, '06
From Soda
Mornings/afternoons are fine because there's no moisture built up but once it hits teens to single digit temps my windows would fog the hell up. I've cleaned it with so many different solutions that I've run out of ideas. Turning up the heat doesn't help, same with cooling it. It'll keep building up and im getting sick of driving with fog smears and not seeing at night. I have to wipe every 5 minutes or so lol. I do have a 24 inch crack across my windshield but that should affect be wise I've driven cars with cracked windshield and its been fine. Heater core is good since its blowing hot heat....going to change coolant and see if that helps. Anyone have any other ideas or experiences that may help solve the issue? Sorry it may not make any sense because im just rambling things out from my phones. Thanks!
Replies (1 - 13)
post Dec 30, 2011 - 2:57 AM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
just turn on defrost with heat and ac on and outside air. you'll have to let it run for a few minutes, but thats what ive done to get it to work here in the teens and single digit mornings... ive always had more trouble on hot summer days after its rained.
This post has been edited by d3ath2009: Dec 30, 2011 - 2:58 AM
post Dec 30, 2011 - 8:18 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
In Australia you can buy a spray stuff leaves an invisible film on the window and pretty well stops it fogging up, can't remember the name though tongue.gif
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Dec 30, 2011 - 12:04 PM
EKAn
Joined Apr 24, '07
From CA
QUOTE (Cuts_the_Pilot @ Dec 30, 2011 - 2:18 PM) *
fog-x? try rubbing in shaving cream on the windoww like your waxing it then wipe it off, heard that helps
what hes saying is if you put blue lights in you car youll lose hp.
post Dec 30, 2011 - 12:17 PM
block
Joined Jul 27, '06
From Soda
QUOTE (d3ath2009 @ Dec 30, 2011 - 1:57 AM) *
tried that, didnt' work.
i've tried everything. cleaned the front, back, sides about 20 times. made sure it was super clean and sure enough once nightfall comes and i start the engine, it fogs. i dont have issues with it in the morning/afternoons but it's at nights when the temp drop and it's dark. oh well if it doesn't work out, im storing it right back into the garage. im getting a honda crv in the next week or so, so it'll go back to sleep just like last year.
post Dec 30, 2011 - 3:55 PM
diegohiga
Joined May 4, '09
From coral springs florida US
This post has been edited by diegohiga: Dec 30, 2011 - 3:56 PM
post Dec 30, 2011 - 4:52 PM
Cuts_the_Pilot
Joined Dec 15, '02
Have a look under your carpet, in the boot etc, you may have some standing water in your car that is causing the fogging.
This post has been edited by Cuts_the_Pilot: Dec 31, 2011 - 6:34 PM
post Dec 31, 2011 - 12:30 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Make sure the AC is ON when you're trying to defrost. Otherwise you're just blowing moist hot air and it won't clear anything. Common places for moisture leaks: rear fender wells rot out and it gets in there, buildup in the body drains from clogged drain plugs.
post Dec 31, 2011 - 1:37 PM
richee3
Joined Jun 29, '08
From Denver
I think it's just a trait of Celicas. Both of mine that I actually drove did the same thing.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 31, 2011 - 6:31 PM
block
Joined Jul 27, '06
From Soda
I dont know but it's pissing me off. I'm closing my house on the 7th of Feb so I'm going to be buying a CRV tomorrow so I don't have to deal with this BS. I hate dealing with this issue because it's quite dangerous to drive at night when I drive home from work. I'll slowly part everything and see if water's somehow getting inside. It'll be a gutted poo poo car anyways since I'll have 4 (IS300, CRV, Corolla, and the Echo) other cars to drive haha...5 if I get a 06-11 Civic Hybrid lol. Oh well thanks guys. wink.gif
post Jan 1, 2012 - 2:39 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
Welcome to the wonderful world of heater cores!!! You're gonna love it here. I just got done with the pleasure of both spending my Boxing Day in my Celi pulling the dash. Wait, I mean the entire freakin interior. Did I forget to mention the savings??? Yup, reach into your savings and grab $391 ($318 if you're in the biz) and hand it to the dealer so they can get a brand new one. Grab your handy dandy AC recovery machine and remove refrigerant. Then undo your coolant lines.
Remove console, glove box, under craps, then remove steering wheel (disconnect battery), pull dash, remove AC box then heater box, blah blah blah.
To make life easier order the little o-rings the hook the stub pipes to the core.
When you pull the core you'll notice the core had a weep inside where the fins are. Hit me up if you need any pointers.
Oh and don't disconnect the harness behind the center vents. You'll spend a few days wondering why your locks don't work.
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
post Jan 1, 2012 - 4:49 PM
RobbMeeX
Joined Dec 30, '11
just saw this was a trash car. nevermind. Set it on fire.
This post has been edited by RobbMeeX: Jan 1, 2012 - 4:52 PM
post Jan 2, 2012 - 2:45 PM
block
Joined Jul 27, '06
From Soda
QUOTE (RobbMeeX @ Jan 1, 2012 - 1:39 PM) *
$318/$391 and you just got ripped. I've replaced the heater core on one of my previous 6g celica before and it wasn't that bad. Oh well, it wasn't my heater core that was the problem. Easy fix was a plug. wink.gif
post Jan 2, 2012 - 6:18 PM
RobbMeeX
Joined Dec 30, '11
The options were $300 from the dealer or $220 from autozone. I chose the factory because it lasted this long and 230000 miles. This cars a keeper for me. You're right, its not that bad, just not how I wanted to spend my day off from work. rolleyes.gif
Lo-Fi Version Time is now: February 26th, 2026 - 12:49 PM
