> re gearing s54, has anyone done it?
post Jan 8, 2012 - 11:42 PM
99gt3sge
Joined Jun 7, '11
From so cal
i have red some of the threads, i was wondering if anyone has changed out their fifth gear from a s54 to s51? was wondering if the rpm drop was drastic? also if anyone has completly re-geared their s54 from first thru fifth? the reason i ask is because my third gear grinds and the front shaft bearings sounds like its gone bad already. so since im going to crack it open was wondering if i can re gear it. aside from finding a lsd for it.
- 99gt3sge   re gearing s54   Jan 8, 2012 - 11:42 PM
- - BonzaiCelica   QUOTE (99gt3sge @ Jan 8, 2012 - 11:4...   Jan 9, 2012 - 3:44 AM
- - 99gt3sge   were those the camrys that came with the 1sfe?   Jan 10, 2012 - 1:23 AM
|- - BonzaiCelica   QUOTE (99gt3sge @ Jan 10, 2012 - 1:2...   Jan 10, 2012 - 2:58 AM
- - AMCMoe   I considered swapping 5th gear in my s54 a few yea...   Jan 10, 2012 - 8:44 AM
- - AMCMoe   Using the same gearing calculator mentioned in the...   Jan 10, 2012 - 10:10 AM
- - stephen_lee   so a 300 rpm drop @ 70 basically nice difference   Jan 10, 2012 - 11:41 AM
- - AMCMoe   About 375rpm drop at 70mph with stock size tires. ...   Jan 10, 2012 - 1:36 PM
- - mkernz22   now here's the question. Will the S51 swap ont...   Jan 10, 2012 - 1:54 PM
|- - kurt95gt   QUOTE (mkernz22 @ Jan 10, 2012 - 1:5...   Jan 10, 2012 - 1:56 PM
- - stephen_lee   you can swap ONLY the 5th gear. which will NOT req...   Jan 10, 2012 - 6:20 PM
|- - mkernz22   QUOTE (stephen_lee @ Jan 10, 2012 - 6...   Jan 11, 2012 - 12:39 AM
- - stephen_lee   oh ya you can lol but its more work lol.   Jan 11, 2012 - 9:47 AM
- - 99gt3sge   I kkow is an old post but, today I bought two tran...   May 6, 2012 - 9:46 PM
- - mkernz22   I believe it should be the gear with more teeth be...   May 6, 2012 - 9:51 PM
- - BonzaiCelica   get the final drive from a euro s54 transmission. ...   May 7, 2012 - 3:21 AM
- - 99gt3sge   I swapped the fifth of the Camry to my 3rd Gen s54...   May 10, 2012 - 12:32 AM
|- - BonzaiCelica   QUOTE (99gt3sge @ May 10, 2012 - 12...   May 10, 2012 - 3:24 AM
|- - purplegt4   QUOTE (99gt3sge @ May 10, 2012 - 1:3...   May 10, 2012 - 10:56 AM
- - pgiorgio   QUOTE (99gt3sge @ Jan 8, 2012 - 11:4...   May 10, 2012 - 7:05 AM
- - mkernz22   QUOTE (99gt3sge @ May 10, 2012 - 1:3...   May 10, 2012 - 11:01 AM
- - 99gt3sge   I'm runing 205/50/15, with old set up I was d...   May 10, 2012 - 1:27 PM
- - BonzaiCelica   thats your problem no wonder why your gears are so...   May 10, 2012 - 2:20 PM
Lo-Fi Version Time is now: August 26th, 2026 - 7:16 PM
