Jan 10, 2012 - 1:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
I installed 8 inch subs in my doors an of course they rattle like crazy now
Would that stick on sound deadner help or does anyone have a low Buck solution to the problem Thanks in advance -------------------- 95 gt coupe, v6 swap weekend toy
Jan 11, 2012 - 9:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Depends what is rattling..Figure that out haha. My money is on the exterior door handle.
Jan 11, 2012 - 9:13 PM
Lol thanks honestly it seems like it's the whole door vibrating
Causing the rattle sound -------------------- 95 gt coupe, v6 swap weekend toy
Jan 11, 2012 - 9:17 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
x2 on finding out what exactly is making the noise.
if you press against the door panel from the inside, does it still rattle? i found mine rattled along the top of the door panel. the metal piece that extends along the top of the interior door panel that hooks onto the metal door frame, well that so-called hook piece widens over time as you close the door shut. it just needed to be bent back tighter to secure the panel on the door frame. otherwise, other common sources for vibration on the door is the door handle (just bend the bracket that secures the 10mm bolt further inwards) and the plastic pivot on the metal door panel that connects the mechanical rods for the latch and manual door lock (a thick piece of foam padding kept it pressed between the door panel and metal door frame). my doors didn't rattle after that even on the highest volume. This post has been edited by azian_advanced: Jan 11, 2012 - 9:18 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jan 11, 2012 - 10:48 PM
Ok so going through an making sure everything is good an tight should help
an if i push on the door skin it stops so I'm guessing that's door handle then -------------------- 95 gt coupe, v6 swap weekend toy
Jan 12, 2012 - 3:03 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
Go to a car audio place and buy some dynamat, i'm not sure what it's called in the states but its a sound deadoning matt, its a thick heavy matt, sicky on one side and thin alloy sheet on the other. Put a large section directly behind the woofer (on the INSIDE of the OUTER door skin) and on the INSIDE of the INNER door skin.
-------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Jan 12, 2012 - 10:22 AM
OK
I'll try to pick some up soon I didn't think with a 300 Watt sub is would be as bad as it is -------------------- 95 gt coupe, v6 swap weekend toy
Jan 12, 2012 - 2:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Jan 12, 2012 - 5:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
My doors have rattles just from my exhaust. I just hit the door and it goes away most of the time haha |
Jan 12, 2012 - 7:17 PM
that's probably what ill be doing for awhile
| Lo-Fi Version | Time is now: June 24th, 2026 - 3:18 AM |
