> 3sge, removing crankshaft pulley bolt, .
post Jan 15, 2012 - 4:25 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Hi guys, I am currently helping out a mate with a 3sge, replacing the waterpump, my question is how to get the crankshaft pulley bolt and would the bolt turn clockwise or anti clockwise to REMOVE the bolt? The timing cover needs to come off..
Thanks
post Jan 15, 2012 - 4:57 PM
mkernz22
Joined May 10, '10
From MA
There's a write up on how to do it in the stickies
http://www.6gc.net/forums/index.php?showto...mp;#entry615588
This post has been edited by mkernz22: Jan 15, 2012 - 4:59 PM
post Jan 15, 2012 - 8:14 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
there are no bolts or nuts that are backwards. everything is righty tighty, lefty loosy
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 16, 2012 - 1:54 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Smaay @ Jan 15, 2012 - 7:14 PM) *
i use an impact, and if that doesnt get it, use a breaker bar and bumo the starter
post Jan 16, 2012 - 3:18 PM
PolliS_5S-FE
Joined Aug 29, '08
Well.. the cylinder head isnt on the car and I dont have an impact gun.. any other ways??
post Jan 16, 2012 - 3:28 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
bump the starter.
theres also threaded bolt holes in the pulley but i never had luck with those
post Jan 16, 2012 - 3:46 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
is the engine still in the car? put the car in reverse, step on the brake and that should prevent the engine from turning while you wrench on the bolt
post Jan 16, 2012 - 3:58 PM
czwalga
Joined Sep 27, '10
From pittsburgh
If the engines out of the car, make a piece of metal that bolts to the engine block and the clutch bolt on the flywheel. This prevents the engine from turning over and you dont need an impact.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Jan 18, 2012 - 4:22 PM
PolliS_5S-FE
Joined Aug 29, '08
her cars an auto. frown.gif doesnt work putting it in reverse in an auto right??
Lo-Fi Version Time is now: August 24th, 2026 - 7:19 AM
