> Radiator leaking and other problems, radiator
post Jan 16, 2012 - 2:18 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
A few days ago I realized there was a puddle of coolant under my car so I opened the hood to investigate. There was coolant on the top edge of the radiator and towards the bottom of the car. I took the car
for a spin to figure out where the leak is then I noticed a pin sized hole steam was coming out of on the top plastic part of the radiator...but there is no way all that coolant could come from that little hole. I
took a hole and washed all the coolant off the radiator then waited for my car to warm up. Steam smelling like coolant seemed to be coming from throughout the radiator and the little whole. I am trying to
figure out if I should just put of of those radiator fix it things in there or if I need to replace the entire radiator. Another bizzare thing happened my car took a good 30 seconds to start. Usually it starts up right
away. I hope it has nothing to do with the head gasket. The car has about 197k everything is original. Any ideas?
post Jan 16, 2012 - 3:05 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
well if its overheating, it will kill your headgasket. but if the radiator is leaking, then you need to repair or replace.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 16, 2012 - 3:22 PM
EKAn
Joined Apr 24, '07
From CA
And i would suggest a replace since the radiator is probably old now and doesn't have much life left in it.
what hes saying is if you put blue lights in you car youll lose hp.
post Jan 16, 2012 - 8:10 PM
mandrek
Joined May 4, '05
From western MD/NOVA
QUOTE (EKAn @ Jan 16, 2012 - 3:22 PM) *
second that.. good excuse for an upgrade!!!
post Jan 17, 2012 - 1:57 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (mandrek @ Jan 16, 2012 - 9:10 PM) *
Mine was oozing coolant through hairline cracks. It turns a lighter color when its done.
post Jan 18, 2012 - 5:39 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
What would be a good way to test the fans? I noticed the car warmed up all the way to the middle and the fans didnt come on.
post Jan 18, 2012 - 6:29 PM
Neon90424
Joined Jan 19, '11
alll the coolant has to be warm, it will warm up and the thermostat will open and cooler water will flow...the whole circuit has to warm up
post Jan 18, 2012 - 6:59 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
Now, if the car is passed the middle mark and the fans do not turn on.. you can assume there is something wrong with the fans right?
post Jan 18, 2012 - 7:28 PM
Neon90424
Joined Jan 19, '11
dead relay?
post Jan 19, 2012 - 12:48 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
yes, perhaps. Im gonna check that today. But it def looks like the fans are the reason for overheating. It does not turn on at all
post Jan 19, 2012 - 1:45 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
So the fan was not coming on even when the engine was over heating so I removed the plug to the cooling fan switch sensor and the fan turned on. I assumed the sensor was bad and replaced it with a new one at autozone, but when I plugged it back in the fan still did not turn on until I disconected the plug again. Now, I am unsure what is causing the car to over heat...the pine size hole on top of the radiator or the fan
This post has been edited by m2736185: Jan 19, 2012 - 4:58 PM
post Jan 19, 2012 - 8:28 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (m2736185 @ Jan 19, 2012 - 12:45 PM) *
coolant might not be flowing to the sensor. replace the rad,
post Jan 19, 2012 - 8:37 PM
Neon90424
Joined Jan 19, '11
compression test maybe bad hg?
post Jan 19, 2012 - 8:42 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
I hope its not a bad HG. I dont have the pressure meter to do a compression test and I cant tell if the coolant has oil in it because its that red stuff toyota uses.
post Jan 20, 2012 - 10:52 AM
Neon90424
Joined Jan 19, '11
if you pull the spark plugs and they are wet it could be a sign...also sweet smelling smoke from tail pipe, or else autozone should be able to do it if they arent complete retards
post Jan 20, 2012 - 8:49 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
This thread is ridiculous. First replace your rad. Then see what happens with the heat. You should be able to turn the fans on with the ac. Is your car missing? If so think about a headgasket. If not, Do the rad.
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
post Jan 26, 2012 - 12:48 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (m2736185 @ Jan 20, 2012 - 1:42 AM) *
If you had oil in your coolant you would know, red or green you would know...
QUOTE (RobbMeeX @ Jan 21, 2012 - 1:49 AM) *
X2 on this. take your problems one step at a time.
Lo-Fi Version Time is now: August 24th, 2026 - 7:55 PM
