Jan 23, 2012 - 10:54 PM
Enthusiast ![]() Joined Aug 28, '08 From Woolwich, Maine Currently Offline Reputation: 0 (0%) |
Okay, so, on my way home from work i noticed my wipers were moving rather slow. so I put them on a higher setting and still they were slow, so I ignored it and put them back on the intermittent setting and then they stopped working in that setting. I then put them back to full and they work until i got to the gas station, when I turned my car back on they were stuck and now they won't work at all. I'm thinking the motor died.
Could there be something else wrong? I need opinions before I go buy a new motor. |
Jan 25, 2012 - 11:34 PM
Enthusiast ![]() ![]() Joined Jul 29, '11 From chino, Ca Currently Offline Reputation: 4 (100%) |
did you check the connections to make sure there were any corrosion that may result in the slowness to completely stop working or a power wire fried itself in my girlfriends old mercedes that happened quite funny argument but it happens older cars tend to have brittle wiring and it may occur in a crack which then may have set a spot of corrosion do to moisture.
Jan 28, 2012 - 2:28 PM
I replaced the motor and all is well again
| Lo-Fi Version | Time is now: September 2nd, 2026 - 5:33 AM |
