> 7A-FE ITB Project
post Jan 24, 2012 - 4:46 PM
morag
Joined Nov 16, '09
From Bulgaria
I'm Starting Individual throttle bodies project on the 7afe.I'll be putting CBR954RR throttle bodies witch have 40mm inlet on the vacuumed side witch line up fairly good with the Stock 7afe intake manifold. The throttle bodies go from 44mm on the trumpet side to 40mm in the vacuum, witch i think will make good air velocity for the stock FE head.
I intend to make a vacuum box to collect the vacuum from the ITB's and spread them in the bigger hoses for brake,map sensor,Fuel pressure regulator and etc(I have yet to figure out all the detail). I will be using 315cc Supra injector witch i've tested with the stock manifold(And it goes way rich).
What has been done so far is that I've cut the stock intake(Which i've got from the junkyard) and tomorrow i will see where exactly will they match up. I intend to use the stock 7afe injector fuel rail and mount the itb's after it. Tomorrow ITB lining and cutting a bit more if needed. Ah and forgot i will be using stock 7afe map sensor, TPS sensor and cbr1000rr manual idle air controller. If anybody is interested in this I'll be happy to see your opinion. I hope I make all clear tomorrow I'll make some good pics on all parts so far and all i intend to do smile.gif. See how this works out.
- morag   7A-FE ITB Project   Jan 24, 2012 - 4:46 PM
- - bsamps4   Sounds freaking awesome man! Pet Peeve... wit...   Jan 24, 2012 - 5:11 PM
- - Bitter   but the steep angle of the ports inside the head w...   Jan 24, 2012 - 7:51 PM
- - morag   I don't think so. In fact i think steep angle ...   Jan 25, 2012 - 5:38 AM
- - Bitter   Are you going to atleast run some longer duration ...   Jan 25, 2012 - 8:39 AM
- - Smaay   dude that thing is going to be freaking loud!...   Jan 25, 2012 - 5:00 PM
- - RobbMeeX   Will need pics/videos.   Jan 25, 2012 - 11:56 PM
- - morag   This is a low budget build so no cam's YET.I...   Jan 26, 2012 - 6:08 AM
- - morag   here's whats up so far.next step TPS sensor pl...   Jan 27, 2012 - 4:57 PM
- - kurt95gt   Thats gonna look bada$$   Jan 27, 2012 - 11:54 PM
- - morag   so m8's here's the progress ITB's are ...   Feb 2, 2012 - 2:57 PM
- - celica-s   i've always wanted to this. there are ITB...   Feb 3, 2012 - 1:00 AM
- - morag   the thing is that you don't need larger then 4...   Feb 3, 2012 - 4:34 AM
- - dakotahwyatt   I bet that will sound real good when its done   Feb 3, 2012 - 2:00 PM
- - Smaay   please get a better camera   Feb 4, 2012 - 12:06 AM
|- - Syaoran   QUOTE (Smaay @ Feb 4, 2012 - 1:06 AM...   Feb 4, 2012 - 12:49 AM
- - kurt95gt   Hell my phone takes better pics than that   Feb 4, 2012 - 1:13 AM
- - smkr3w   Lookin good. Cant wait for a vid/sound clip once i...   Feb 4, 2012 - 4:36 AM
- - morag   It's actualy a phone camera .And the thing is ...   Feb 4, 2012 - 5:42 AM
- - mandrek   curious to see how well this will work, and how mu...   Feb 4, 2012 - 6:14 AM
- - mandrek   oh, and i must say, i LOVE the vacume tank.   Feb 4, 2012 - 6:26 AM
- - morag   Guys here's the case. . I suspect something is...   Feb 4, 2012 - 1:27 PM
|- - smkr3w   QUOTE (morag @ Feb 4, 2012 - 1:27 PM...   Feb 4, 2012 - 2:33 PM
- - Bitter   your injectors are WAY to big and you have no way ...   Feb 4, 2012 - 6:56 PM
- - morag   the map sensor reading is from a separate vacuum h...   Feb 5, 2012 - 4:11 AM
- - morag   and guys what that vacuum line for coming from the...   Feb 5, 2012 - 4:33 AM
|- - Bitter   QUOTE (morag @ Feb 5, 2012 - 3:33 AM...   Feb 5, 2012 - 10:57 AM
- - morag   the map sensor is on a separate vacuum coming from...   Feb 5, 2012 - 3:51 PM
- - Bitter   You will probably only need injectors slightly lar...   Feb 5, 2012 - 10:50 PM
- - morag   That's what intend to do! Something like B...   Feb 6, 2012 - 6:31 AM
- - celica74   a $50 vacuum manifold would probly work best....   Sep 6, 2012 - 6:50 PM
- - Special_Edy   One common misconception Ive read here is that itb...   Sep 7, 2012 - 8:26 AM
- - Special_Edy   Oh and set every throttlebody the same. The simple...   Sep 7, 2012 - 9:29 AM
- - Bitter   QUOTE (Special_Edy @ Sep 7, 2012 - 9...   Sep 8, 2012 - 6:40 PM
- - Special_Edy   QUOTE (Bitter @ Sep 8, 2012 - 6:40 P...   Sep 9, 2012 - 10:55 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 12:44 AM
