> Gears only shift when car is off
post Jan 27, 2012 - 7:49 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
I have a 95 Celica GT just under 200k. It had problems downshifting before, but I had replaced the gear oil and everything was smooth again. Today I stopped at a light and the car wouldnt shift into first...or second or anything. I turned the car off switched it into first then I was able to get it into second, but it wouldnt go any further or back to first. I had to drive home in second with my hazzard lights on. Luckily I was a mile away from home. The clutch seems like it is still strong. Could this be the pressure plate or something similar?
- m2736185   Gears only shift when car is off   Jan 27, 2012 - 7:49 PM
- - Stambo   possibly the clutch itself is dragging on the flyw...   Jan 27, 2012 - 8:06 PM
- - m2736185   Nope, the clutch comes right back when I release i...   Jan 27, 2012 - 8:23 PM
- - Bitter   clutch isn't disengaging for some reason, got ...   Jan 27, 2012 - 9:12 PM
- - 96stgreendemon   I had this problem too. There is an adjustment on ...   Jan 27, 2012 - 10:02 PM
- - Neon90424   does your clutch pedal vibrate when you push it do...   Jan 27, 2012 - 10:10 PM
- - m2736185   Yes there is fluid in there. I tried to move it it...   Jan 27, 2012 - 10:24 PM
- - RabidTRD   A bad throwout bearing will do that. Did it to my ...   Jan 27, 2012 - 11:14 PM
- - JasonTX   had a very similar problem. a spring on my clutch ...   Jan 27, 2012 - 11:17 PM
- - m2736185   Either way....it looks like everyone is saying its...   Jan 28, 2012 - 12:12 AM
- - JasonTX   pretty good walkthroughs on the site. very straigh...   Jan 28, 2012 - 12:28 AM
- - RabidTRD   Either way, it's not going to hurt to put a ne...   Jan 28, 2012 - 12:38 AM
- - m2736185   Yea, I just wish it could have waited another thou...   Jan 28, 2012 - 2:23 AM
|- - JasonTX   QUOTE (m2736185 @ Jan 28, 2012 - 3:2...   Jan 28, 2012 - 11:14 AM
|- - xrav22   QUOTE (m2736185 @ Jan 28, 2012 - 2:2...   Jan 28, 2012 - 11:15 AM
- - m2736185   Looks like I got one of those 1 day projects that ...   Jan 28, 2012 - 1:04 PM
- - Bitter   if the slave is pushing the fork then the clutch h...   Jan 28, 2012 - 1:46 PM
|- - xrav22   QUOTE (Bitter @ Jan 28, 2012 - 1:46 ...   Jan 28, 2012 - 3:07 PM
- - 4v6   Sounds like clutch drag. I had the same issue on ...   Jan 30, 2012 - 3:28 AM
- - m2736185   Well, I got the undercover off so I could get a go...   Jan 30, 2012 - 11:05 AM
|- - rave2n   QUOTE (m2736185 @ Jan 30, 2012 - 11...   Jan 30, 2012 - 11:23 AM
|- - xrav22   QUOTE (m2736185 @ Jan 30, 2012 - 11...   Jan 30, 2012 - 2:54 PM
- - m2736185   The bearing mount - mean the mounting bracket tha...   Jan 30, 2012 - 11:57 AM
|- - rave2n   QUOTE (m2736185 @ Jan 30, 2012 - 11...   Jan 30, 2012 - 12:21 PM
- - JasonTX   i managed to get the rear mount off without droppi...   Jan 30, 2012 - 1:16 PM
- - m2736185   Second day working on the car and surprisingly no ...   Feb 1, 2012 - 6:07 PM
- - mkernz22   Yeah, you're ABS won't work anymore since ...   Feb 1, 2012 - 6:21 PM
- - m2736185   damnit, I should have just left it on there. Maybe...   Feb 1, 2012 - 6:39 PM
- - mkernz22   it's not even worth trying to get one out of t...   Feb 1, 2012 - 9:14 PM
- - m2736185   Just got both axels out. Got the front mount out a...   Feb 2, 2012 - 10:33 AM
- - mkernz22   Yes, you need to remove the center bolt on the rea...   Feb 2, 2012 - 11:15 AM
- - m2736185   Wow, that rear mount gave me hell, but I got it ou...   Feb 2, 2012 - 5:57 PM
- - mkernz22   the middle bolt can be a pain in the a$...   Feb 2, 2012 - 7:28 PM
- - rave2n   Watch out when dropping that trannie, there are al...   Feb 3, 2012 - 9:19 AM
- - mkernz22   yes, don't forget about the speed sensor. that...   Feb 3, 2012 - 11:35 AM
- - m2736185   Wahoo! I finally got the tranny off. I didnt o...   Feb 3, 2012 - 2:41 PM
- - mkernz22   do not get an f1. just get a regular OEM clutch se...   Feb 3, 2012 - 3:09 PM
- - JasonTX   gonna go with mkernz22 considering your budget, f...   Feb 3, 2012 - 3:57 PM
- - m2736185   I was gonna wait until I get the new parts to take...   Feb 3, 2012 - 7:40 PM
- - Bitter   leaky valve cover gasket, so common on the 5S.   Feb 3, 2012 - 8:49 PM
- - m2736185   Took the clutch off today to see if I could resurf...   Feb 4, 2012 - 3:09 PM
- - Bitter   you need a flywheel. rear main doesn't look to...   Feb 4, 2012 - 4:09 PM
- - Neon90424   I had an F1 in my 7gc...worked pretty good for me....   Feb 4, 2012 - 5:28 PM
- - mkernz22   if you had any oil on the flywheel bolts, replace ...   Feb 4, 2012 - 6:14 PM
- - m2736185   Damnit I guess I got 2nd day delivery on the clutc...   Feb 4, 2012 - 11:19 PM
- - JasonTX   rear main does not look bad. (its the rubber that ...   Feb 4, 2012 - 11:29 PM
|- - mkernz22   QUOTE (JasonTX @ Feb 4, 2012 - 11:29...   Feb 4, 2012 - 11:37 PM
|- - JasonTX   QUOTE (mkernz22 @ Feb 5, 2012 - 12:3...   Feb 5, 2012 - 12:01 AM
- - m2736185   Does anyone know the part number for the rear main...   Feb 5, 2012 - 2:23 AM
- - m2736185   I checked the manual and I couldnt find the torque...   Feb 6, 2012 - 3:39 PM
- - m2736185   Well for anyone replacing the main seal DO NOT rem...   Feb 7, 2012 - 6:34 PM
- - rave2n   Lol, did you use a jack or something to do the tra...   Feb 7, 2012 - 6:46 PM
- - m2736185   Ha I tried to use the jack at first, but I couldnt...   Feb 7, 2012 - 8:43 PM
- - m2736185   I think im done tryin to get everything to the rig...   Feb 8, 2012 - 4:41 PM
- - mkernz22   don't always go by specifications. do it until...   Feb 8, 2012 - 5:29 PM
- - m2736185   lol, yes I think im gonna use the "really tig...   Feb 8, 2012 - 9:24 PM
Lo-Fi Version Time is now: July 31st, 2026 - 12:46 PM
