Jan 27, 2012 - 7:49 PM
Enthusiast ![]() Joined Jun 4, '10 From Jax Beach, FL Currently Offline Reputation: 0 (0%) |
I have a 95 Celica GT just under 200k. It had problems downshifting before, but I had replaced the gear oil and everything was smooth again. Today I stopped at a light and the car wouldnt shift into first...or second or anything. I turned the car off switched it into first then I was able to get it into second, but it wouldnt go any further or back to first. I had to drive home in second with my hazzard lights on. Luckily I was a mile away from home. The clutch seems like it is still strong. Could this be the pressure plate or something similar?
m2736185 Gears only shift when car is off Jan 27, 2012 - 7:49 PM
Stambo possibly the clutch itself is dragging on the flyw... Jan 27, 2012 - 8:06 PM
m2736185 Nope, the clutch comes right back when I release i... Jan 27, 2012 - 8:23 PM
Bitter clutch isn't disengaging for some reason, got ... Jan 27, 2012 - 9:12 PM
96stgreendemon I had this problem too. There is an adjustment on ... Jan 27, 2012 - 10:02 PM
Neon90424 does your clutch pedal vibrate when you push it do... Jan 27, 2012 - 10:10 PM
m2736185 Yes there is fluid in there. I tried to move it it... Jan 27, 2012 - 10:24 PM
RabidTRD A bad throwout bearing will do that. Did it to my ... Jan 27, 2012 - 11:14 PM
JasonTX had a very similar problem. a spring on my clutch ... Jan 27, 2012 - 11:17 PM
m2736185 Either way....it looks like everyone is saying its... Jan 28, 2012 - 12:12 AM
JasonTX pretty good walkthroughs on the site. very straigh... Jan 28, 2012 - 12:28 AM
RabidTRD Either way, it's not going to hurt to put a ne... Jan 28, 2012 - 12:38 AM
m2736185 Yea, I just wish it could have waited another thou... Jan 28, 2012 - 2:23 AM
JasonTX QUOTE (m2736185 @ Jan 28, 2012 - 3:2... Jan 28, 2012 - 11:14 AM
xrav22 QUOTE (m2736185 @ Jan 28, 2012 - 2:2... Jan 28, 2012 - 11:15 AM
m2736185 Looks like I got one of those 1 day projects that ... Jan 28, 2012 - 1:04 PM
Bitter if the slave is pushing the fork then the clutch h... Jan 28, 2012 - 1:46 PM
xrav22 QUOTE (Bitter @ Jan 28, 2012 - 1:46 ... Jan 28, 2012 - 3:07 PM
4v6 Sounds like clutch drag.
I had the same issue on ... Jan 30, 2012 - 3:28 AM
m2736185 Well, I got the undercover off so I could get a go... Jan 30, 2012 - 11:05 AM
rave2n QUOTE (m2736185 @ Jan 30, 2012 - 11... Jan 30, 2012 - 11:23 AM
xrav22 QUOTE (m2736185 @ Jan 30, 2012 - 11... Jan 30, 2012 - 2:54 PM
m2736185 The bearing mount - mean the mounting bracket tha... Jan 30, 2012 - 11:57 AM
rave2n QUOTE (m2736185 @ Jan 30, 2012 - 11... Jan 30, 2012 - 12:21 PM
JasonTX i managed to get the rear mount off without droppi... Jan 30, 2012 - 1:16 PM
m2736185 Second day working on the car and surprisingly no ... Feb 1, 2012 - 6:07 PM
mkernz22 Yeah, you're ABS won't work anymore since ... Feb 1, 2012 - 6:21 PM
m2736185 damnit, I should have just left it on there. Maybe... Feb 1, 2012 - 6:39 PM
mkernz22 it's not even worth trying to get one out of t... Feb 1, 2012 - 9:14 PM
m2736185 Just got both axels out. Got the front mount out a... Feb 2, 2012 - 10:33 AM
mkernz22 Yes, you need to remove the center bolt on the rea... Feb 2, 2012 - 11:15 AM
m2736185 Wow, that rear mount gave me hell, but I got it ou... Feb 2, 2012 - 5:57 PM
mkernz22 the middle bolt can be a pain in the a$... Feb 2, 2012 - 7:28 PM
rave2n Watch out when dropping that trannie, there are al... Feb 3, 2012 - 9:19 AM
mkernz22 yes, don't forget about the speed sensor. that... Feb 3, 2012 - 11:35 AM
m2736185 Wahoo! I finally got the tranny off. I didnt o... Feb 3, 2012 - 2:41 PM
mkernz22 do not get an f1. just get a regular OEM clutch se... Feb 3, 2012 - 3:09 PM
JasonTX gonna go with mkernz22
considering your budget, f... Feb 3, 2012 - 3:57 PM
m2736185 I was gonna wait until I get the new parts to take... Feb 3, 2012 - 7:40 PM
Bitter leaky valve cover gasket, so common on the 5S. Feb 3, 2012 - 8:49 PM
m2736185 Took the clutch off today to see if I could resurf... Feb 4, 2012 - 3:09 PM
Bitter you need a flywheel.
rear main doesn't look to... Feb 4, 2012 - 4:09 PM
Neon90424 I had an F1 in my 7gc...worked pretty good for me.... Feb 4, 2012 - 5:28 PM
mkernz22 if you had any oil on the flywheel bolts, replace ... Feb 4, 2012 - 6:14 PM
m2736185 Damnit I guess I got 2nd day delivery on the clutc... Feb 4, 2012 - 11:19 PM
JasonTX rear main does not look bad. (its the rubber that ... Feb 4, 2012 - 11:29 PM
mkernz22 QUOTE (JasonTX @ Feb 4, 2012 - 11:29... Feb 4, 2012 - 11:37 PM
JasonTX QUOTE (mkernz22 @ Feb 5, 2012 - 12:3... Feb 5, 2012 - 12:01 AM
m2736185 Does anyone know the part number for the rear main... Feb 5, 2012 - 2:23 AM
m2736185 I checked the manual and I couldnt find the torque... Feb 6, 2012 - 3:39 PM
m2736185 Well for anyone replacing the main seal DO NOT rem... Feb 7, 2012 - 6:34 PM
rave2n Lol, did you use a jack or something to do the tra... Feb 7, 2012 - 6:46 PM
m2736185 Ha I tried to use the jack at first, but I couldnt... Feb 7, 2012 - 8:43 PM
m2736185 I think im done tryin to get everything to the rig... Feb 8, 2012 - 4:41 PM
mkernz22 don't always go by specifications. do it until... Feb 8, 2012 - 5:29 PM
m2736185 lol, yes I think im gonna use the "really tig... Feb 8, 2012 - 9:24 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 10:55 AM |
