Feb 2, 2012 - 4:56 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
just wondering how everyone has theirs hooked up, and does anyone know if where the stock catch can would go the smaller line coming from the lower side of the crank that was spitting oil when i forgot to connect it can be blocked? if im using an aftermarket catch can would that be ok to do or am i just asking for problems here? any input is much appreciated. ill try and get pics of what i am talking about later.
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Feb 3, 2012 - 3:38 PM
Bump.... Anything?
Feb 3, 2012 - 6:34 PM
Enthusiast ![]() Joined Feb 23, '10 From Vancouver, BC Currently Offline Reputation: 0 (0%) |
I am just using the stock catch can/lines.....st205 WRC.
Are you talking about the line coming off of the PCV valve? How is your aftermarket catch can hooked up? How is the crankcase getting vented with how you have it set up? Just make sure that the crankcase is able to relieve excess pressure through the PCV valve and I think you should be okay. |
Feb 5, 2012 - 10:57 AM
just wondering how everyone has theirs hooked up, and does anyone know if where the stock catch can would go the smaller line coming from the lower side of the crank that was spitting oil when i forgot to connect it can be blocked? if im using an aftermarket catch can would that be ok to do or am i just asking for problems here? any input is much appreciated. ill try and get pics of what i am talking about later. the stock setup is probably your best bet since it does incoperate that drain. if your running an aftermarket can, hook it up like stock, ( line from valve cover to the can, and a line from the can to your intake, pre turbo) and if it dont have a drain, cap the fitting on the back of the head. -------------------- Former Team 5SFTE pro member ;)
Feb 6, 2012 - 10:47 AM
Enthusiast ![]() ![]() Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) |
I'm in the process of doing a 3rd gen swap for a friend, going to cap the port on the head, and use the PCV and the big breather line to run into the intake pre turbo via a custom intake pipe. Should work out well
The OEM catch tank set up is TITS, but I did not get the can with the engine |
Feb 6, 2012 - 12:08 PM
I had the stock one, but accidentally shipped it off when I sold my W2A setup.... But the drain line can be capped off is what I believe I am hearing
Feb 6, 2012 - 6:34 PM
I had the stock one, but accidentally shipped it off when I sold my W2A setup.... But the drain line can be capped off is what I believe I am hearing Yep you can, just make sure what you use to cap it is compatible with oil. If you use a standard rubber the oil will break it down and eventually leak Cheers Luke |
| Lo-Fi Version | Time is now: June 21st, 2026 - 10:26 AM |
