Feb 3, 2012 - 10:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
So I'm going to be wiring up my fogs soon and what I'm planning to do is just reroute the wires to the sidemarker and send those straight to the fog lights and to splice in the sidemarkers to the turn signal's wires so they'll both blink.
Basically what I'm worried about is: Is this feasible? Will I be blowing fuses? Any input is appreciated. This post has been edited by HectortheRican: Aug 8, 2012 - 6:43 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
HectortheRican Question about wiring fogs Feb 3, 2012 - 10:20 PM
SupraKid Yea it MAY work, but youll run the risk of blowing... Feb 3, 2012 - 11:30 PM
CAcelica29 @suprakid : sop in the case of fogs ANY 12v toyota... Feb 4, 2012 - 4:18 AM
richee3 I'm confused. You're going to use your tin... Feb 4, 2012 - 6:49 PM
HectortheRican QUOTE (richee3 @ Feb 4, 2012 - 6:49 ... Feb 5, 2012 - 12:35 AM
richee3 Oh, ok. I thought I just misunderstood something a... Feb 5, 2012 - 9:43 AM
mkernz22 People have wired them to the side markers before,... Feb 5, 2012 - 7:52 PM
trdproven the sidemarkers electrical is only meant to run th... Feb 9, 2012 - 6:11 PM
soulshadow 55 watt is only 4.5 amps. If you wire it into a 12... Feb 12, 2012 - 8:00 PM
trdproven you might as well just run your own independant wi... Feb 13, 2012 - 11:59 PM
Box I'm thinking about doing the same thing. I fo... Mar 5, 2012 - 11:53 PM
HectortheRican So I found a diagram to wire my fog lights indepen... Aug 8, 2012 - 6:48 PM
travisxcore QUOTE (HectortheRican @ Aug 8, 2012 - 7... Aug 8, 2012 - 9:20 PM
HectortheRican QUOTE (travisxcore @ Aug 8, 2012 - 9... Aug 9, 2012 - 12:07 PM
BillyM81 Would you use that diagram to wire up a hid kit to... Aug 9, 2012 - 6:00 PM
travisxcore I doubt it actually goes to a power wire cause its... Aug 9, 2012 - 7:54 PM
HectortheRican QUOTE (travisxcore @ Aug 9, 2012 - 7... Aug 10, 2012 - 1:00 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:46 PM |
