Feb 7, 2012 - 1:12 AM
Enthusiast Joined May 24, '11 From Glendale, AZ Currently Offline Reputation: 0 (0%) |
Any hints out there on how to get the thermostat housing nuts off successfully? I finally got the upper one off using vise grips after both my socket and wrench stripped the nut. I swear these things are made out of aluminum. The lower one is starting to strip using the wrench, and I can't get a socket in there between the nut and the A/C compressor. I'm in the middle of a timing belt/water pump replacement and wanted to put a new thermostat in. Should I pull the compressor?
warthog1 Thermostat housing nuts striping (5SFE) Feb 7, 2012 - 1:12 AM
Araykhel Those damn things. I should show you the carnage o... Feb 7, 2012 - 1:30 AM
Bitter you need a better wrench or socket then, the chine... Feb 7, 2012 - 8:35 AM
Spider77 I had this same issue a while back when I wanted t... Feb 7, 2012 - 9:21 AM
azian_advanced yes remove the compressor. 3 12mm bolts hold it t... Feb 7, 2012 - 3:28 PM
warthog1 Thanks guys, I removed the compressor, used a 6 p... Feb 7, 2012 - 10:11 PM
bnr32celica I used a 10mm socket on a 1/4" ratchet with a... Feb 8, 2012 - 2:16 AM
k-weaver I just used a swivel socket to get mine off. Was a... Feb 10, 2012 - 2:33 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:58 PM |
