Feb 8, 2012 - 1:50 PM
Enthusiast ![]() Joined Nov 24, '10 From Worth, IL Currently Offline Reputation: 5 (100%) |
Hello, my name is Matt, selling some of the stuff I have from converting over.
Low ballers welcome, worst I can say is NO or counteroffer. Please text seven08-37two-1six85 or email me at plachamaciej@yahoo.com Im not here regularly so its easier to get a hold of me via TxMsg or email. UPDATE more parts.........................prices as follows. St215 TMIC "intercooler" cosmetic damage, fully functional, ..............125..........shipped 5SFE oil pan great to do oil return for turbo setup, has hole by drain plug, plugged by rubber plug, ......50........shipped 3rd Gen 3SGTE TB extension inlet, will not fit 2nd Gen, this it the bigger TB version what ever 3rd Gen is,..... 60...........shipped. Also got 2 starters that will fit 5spd trans......... asking 30+postage St215 3SGTE ECU A/T trans works fine tested on car, speed cut active on it still at 120MPH wont go past it needs something like HKS or Greddy speed defender wired into harness. ![]() ![]() ![]() ![]() ![]() ![]() ![]() more parts and updated pics,,,, if no price please ask. New stuff added ST215 3SGTE injectors aqua colored 540CC high impedance(no resistor box required) asking 230 shipped for set of 4 injectors,,, I have 2 sets for sale...tested working St215 3SGTE A/T ECU tested working as stated above asking .........220...... shipped 5SFE M/T ECU came off of my '94 GT.......asking 60 shipped 5SFE A/T ECU came off of '97+ Camry with distributeless ignition and crank angle sensor type......asking 60 shipped St215 3SGTE Top Mount intercooler as stated above 125 shipped 3rd Gen Rev3 throttle body adapter/spacer only 3rd gen spec motor TB it will fit.........60...shipped 6GC gauge cluster all gauges work..tested.... comes with KPH speedo that came off of my JDM cluster, just needs your speedo swapped for odometer easy swap......40...shipped ![]() ![]() ![]() 6GC kouki tail lamps both sides L+R,,,,,, Im selling ether LED moded and slightly tinted/smoked tails(their on car at the moment) or totally stock Kouki lights with no mods. Led moded lights have been opened in the rear and led circuit board installed, then they were resealed, I got them like that, and they look bad azz at night. OEM tails are just that oem kouki's have a crack but its like on inside of lense on right tail lamp I think it doesnt affect their function one bit. IM KEEPING A SET FOR THE CAR, I JUST DONT NEED 2 SETS, SO SOMEONE CAN CHOOSE WHICH ONES THEY WANT. LED Kouki type asking 275 shipped--------> I'll try to get night shot if interested. OEM kouki asking 225 shipped------------->just your normal Kouki tails. ![]() 94+ 6GC GT 5SFE 5spd trans,,,, comes with shift cables and axles TOB and fork. asking 300 picked up only I'll will not ship nor will I look into finding prices ![]() ![]() ![]() 97+ Camry cylinder head DIS type but with removing plug can run distributor system on this head with no problems. I will include intake manifold, ether a 97+ or the older IM that fits this head, older type IM had TB and valves on it, I should have the TB for the newer too just have to find it. There was no issues with motor or head, head just came off for GTE head, has no bent valves or any damage Im asking 200 for head+IM (you choose which IM you want) ...........can probably ship but will be expensive better to pick up, comes with valves/springs/retainers/keepers/lifters-buckets. ![]() ![]() ![]() ![]() ![]() 2nd Gen 3SGTE hydraulic belt tensioner.....BRAND NEW...0miles...found out hard way it wont fit my ST215 and why, need it gone..... 60 shipped takes it. ![]() 3SGTE water pump back cover ( T-stat housing) brand new should work on ST185 and such, I will throw in water pipes with oil cooler with this or can part it out......BRAND NEW COVER)......asking for cover+pipes+oil cooler 140........ shipped...... ![]() ![]() Pile of stuff............if you see anything just ask I'll get price shipped for it..... think there's a E153 trans top bracket need to verify tho, 2 good starters for S-series S53 trans. 5SFE distributor, 93+ corolla Manual pedals Brake+clutch with master might fit Celica -93 or 94+ not sure tho. ![]() ![]() Thanks for looking at my stuff. Mid/late Sep I'll be posting my 5SGTE partially assembled motor...so stay tuned. This post has been edited by placham: Aug 15, 2012 - 6:01 PM |
placham FS: 6GC tails/front lamps/fenders/ST215 3SGTE ECU's/ 5SGTE Feb 8, 2012 - 1:50 PM
ricochet1490 jdm tail light dibs - do you have any pics of thos... Feb 8, 2012 - 11:27 PM
mkernz22 QUOTE (ricochet1490 @ Feb 8, 2012 - 11... Feb 8, 2012 - 11:34 PM
ricochet1490 QUOTE (mkernz22 @ Feb 8, 2012 - 11:3... Feb 8, 2012 - 11:37 PM
placham QUOTE (ricochet1490 @ Feb 8, 2012 - 11... Feb 9, 2012 - 2:32 AM
placham Items moved to top of post. Feb 9, 2012 - 6:09 PM
placham Edited oil pan sold, pics removed. Feb 9, 2012 - 8:28 PM
xs94st Shipping cost of passenger fender to 92882 plz =] Feb 10, 2012 - 5:42 PM
placham QUOTE (xs94st @ Feb 10, 2012 - 6:42 ... Feb 10, 2012 - 8:27 PM
808celica I give you $30+shipping priority to Hawaii 96... Feb 14, 2012 - 4:33 AM
placham QUOTE (808celica @ Feb 14, 2012 - 4... Feb 14, 2012 - 10:45 AM
808celica QUOTE (placham @ Feb 14, 2012 - 5:45... Feb 15, 2012 - 2:09 AM
warthog1 Just received the head and tail lights. Thanks Ma... Feb 15, 2012 - 5:04 PM
placham QUOTE (warthog1 @ Feb 15, 2012 - 6:0... Feb 15, 2012 - 7:04 PM
Driver Hey! I'm interested in those water lines a... Feb 15, 2012 - 8:54 PM
placham QUOTE (Driver @ Feb 15, 2012 - 8:54 ... Feb 16, 2012 - 12:33 AM
Driver Saturday works for me! PM'd Feb 16, 2012 - 12:43 AM
Lindsley do you have the st215 head? Mar 11, 2012 - 6:42 PM
placham QUOTE (Lindsley @ Mar 11, 2012 - 6:4... Mar 12, 2012 - 9:35 PM
Skinerp89 which fenders do you have and how much? would nto... Mar 13, 2012 - 10:31 AM
199celica are you willing to part out the headlight set? if ... Mar 13, 2012 - 11:53 AM
placham QUOTE (199celica @ Mar 13, 2012 - 12... Mar 14, 2012 - 2:50 AM
toyotaep82 QUOTE (placham @ Mar 14, 2012 - 2:50... Mar 30, 2013 - 11:50 AM
199celica all i need is the mounting bracket and a semi good... Mar 14, 2012 - 11:39 AM
placham Bump............................ added more parts ... Aug 15, 2012 - 6:03 PM
placham no one needs these parts I know their hard to get.... Aug 21, 2012 - 9:44 PM
placham 3SGTE A/T ECU and 3rd Gen Rev3 TB adapter sold.
B... Aug 28, 2012 - 2:53 PM
pitcelica How much for one of the S53 starter shipped to G0X... Sep 4, 2012 - 7:19 PM
placham QUOTE (pitcelica @ Sep 4, 2012 - 8:1... Sep 7, 2012 - 12:27 PM
pitcelica Sorry for the delay. Yes I'm still interested ... Oct 2, 2012 - 3:19 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 8:11 PM |
