> v6 /s54 combo, bearing carrier question
post Feb 10, 2012 - 11:40 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok so ive done alittle research but havent found alot of info
i did read i need a spacer like a 3s running a s54 does but idk where to find one at or is that something i need to make
Any info on this would be great
94 st hatch my daily driver
n
Replies (1 - 9)
post Feb 11, 2012 - 12:36 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (kurt95gt @ Feb 11, 2012 - 12:40 AM) *
if your running an e153 transmission on your v6 motor you'll need a spacer in your axles. and the axle hybrid setup.
if your using s54 all you need are oem axles and your done...
post Feb 11, 2012 - 12:40 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I know that much
But reading through so much i thought i needed a spacer to mount the bearing carrier to so i could mount it to the block
Maybe i just need an adapter plate
n
post Feb 11, 2012 - 10:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (BonzaiCelica @ Feb 10, 2012 - 9:36 PM) *
thats correct but not what hes looking for.
you need to design a bearing carrier that bolts to the 1MZ and fits the stock axles. ill design one when i get to that point. it looks like you are ahead of me
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 11, 2012 - 10:27 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Idk if im ahead or not lol
But im thinking ahead
If everything goes as i hope tomorrow ill be dropping the motor an trans in temp to make the mounts. An maybe snap a few pics
Have you read anything on how the mount needs to be made.
Anything about thickness the mount needs to be?
n
post Feb 12, 2012 - 10:59 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i would look at the mounts that Gouky makes for the MR2. i have a feeling that ill have to fab up something totally new. if i get ahead of you, ill make 2 for ya.
post Feb 13, 2012 - 12:02 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I talked to celicast95 an asked him about the bearing carrier mount an the mr2 doeant have the bearing to need a bearing carrier
n
post Feb 13, 2012 - 11:36 AM
richee3
Joined Jun 29, '08
From Denver
FWD will have to have that bracket. I'm curious if the 1MZ will sit further away from the firewall or closer to it than the 5S. If it sits farther away, I wonder if you could recycle the 5S bracket with longer bolts and washers between the bracket and the block to act as spacers.
Or have I missed the issue? Does the 5S bracket not bolt up to the 1MZ?
This post has been edited by richee3: Feb 13, 2012 - 11:39 AM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 13, 2012 - 12:17 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I don't know what the bracket looks like for the Celica, as I never had a GT Celica, but the 1MZ's bearing carrier mounting area on the block looks like this:
and yeah, the MR2's S54 axles don't have a bearing. Just a long axle.
What you could do is bolt a sheet of metal there and have the Celica carrier mount cut and welded on in the correct place so you don't need to modify anything else.
edit: Like this
This post has been edited by 95CelicaST: Feb 13, 2012 - 12:19 PM
**** Photobucket
post Feb 13, 2012 - 3:15 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
That my basic plan i just need to figure out if i have to cut the mount or if i can just bolt it to a blank plate an bolt that to the motor
n
Lo-Fi Version Time is now: July 30th, 2026 - 4:51 PM
