Feb 12, 2012 - 11:39 PM
Enthusiast ![]() ![]() ![]() Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
Well... ok so, my 98 recently had two episodes that would seem as if the battery would need to be replaced.
1) Was at a park, and the car was still warmish from a fresh drive and it wouldn't start. The odd thing is that when I tried to turn over the engine, all of my lights on my dash died and nothing started. When I got a jump I noticed that my dash clock and stereo clock were forward by 20 minutes and the battery ran the whole drive and several days afterwards absolutely fine with no problems at all. This was the first episode. 2) After work today, the car was cold because it was off for 5 hours in the cold. Once again, the lights on my dash were fine upon key entrance but when I went to turn the motor all the lights died and the battery needed to be jumped again, however, this time both clocks were forward by 2 hours... Once again, after the jump the battery will drive just fine with no signs that it needed to be replaced during the drive (I mean like no dimming of anything, the headlights seemed normal, and no odd sounds). I'm guessing that my battery is probably either the incorrect size, or hopefully this will never happen again. So I guess my main question is => Has anyone ever experienced a dead battery and time shift? -------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Feb 13, 2012 - 8:38 AM
sounds like bad battery connections or cables.
Feb 13, 2012 - 2:54 PM
sounds exactly like poor connection at the terminals. one of my celicas does this same thing. get ya a 10mm wrench and loosen the terminal clamps. wiggle them a bit and re-tighten. you should be good to go
Feb 13, 2012 - 10:18 PM
sounds exactly like poor connection at the terminals. one of my celicas does this same thing. get ya a 10mm wrench and loosen the terminal clamps. wiggle them a bit and re-tighten. you should be good to go You rule Smaay, I've seen you help countless people and you continue to do so! I swear a freakin 10mm wrench solves everything with this car lol -------------------- Brand new 6gc owner! (sort of 2011)
Feb 15, 2012 - 5:19 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
sounds exactly like poor connection at the terminals. one of my celicas does this same thing. get ya a 10mm wrench and loosen the terminal clamps. wiggle them a bit and re-tighten. you should be good to go I'd be tempted to apply a little steel or copper wool to the connectors and terminals first, then hit them both with dielectric grease to ensure a clean connection with corrosion prevention. |
Feb 15, 2012 - 9:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
sounds exactly like poor connection at the terminals. one of my celicas does this same thing. get ya a 10mm wrench and loosen the terminal clamps. wiggle them a bit and re-tighten. you should be good to go I'd be tempted to apply a little steel or copper wool to the connectors and terminals first, then hit them both with dielectric grease to ensure a clean connection with corrosion prevention. Galcobar and Smaay are on the right track. This happened to my Celica about 3 months ago; went outside on particularly cold morning, turned the key, and all electronics in the car just shut off. Seeing as I had a brand new Optima Yellowtop in the car I knew the battery was dead so I disconnected the battery terminals, cleaned them with baking soda, a bit of water, and a toothbrush, and then re-connected them. Car fired up on the first turn of the key. Problem solved. -------------------- Has no more Celicas
Feb 15, 2012 - 9:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
toyotas are built with 10 and 14mm lol almost everything besides suspension is a 10 or a 14
This post has been edited by 4-eyed-freek: Feb 15, 2012 - 9:50 PM -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:55 AM |
