> FS: Gen3 3S-GTE 6Boost turbo manifold+wastegate+screamer pipe
post Feb 14, 2012 - 3:50 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
As the title says I am selling my 6boost turbo manifold, T3 flange, with the 38mm turbosmart Ultragate and screamer pipe.
The name 6Boost probably does not mean much to most of you, but in Australia he (Kyle, the guy behind 6Boost) is one of the biggest names in the business, his business is only building turbo manifolds using his own patented "merge collector", all manifolds are made from steam pipe and have a lifetime warranty against cracking, sagging, etc.
Compared to other manifolds (cheap ebay and expensive HKS ones and more) expect to see lag time decrease of around 200 rpm and make more power (this has been tested by 6Boost himself and various magazines who have done articles on his work, its not just here say).
Selling because since getting a GT3582r the gate is too small and instead of cutting up the manifold and modifying it, then getting it recoated I thought it better to get another one made.
The gate was just fine for the car when I was running the GT3082, and the HKS 3071, so as long as you have a GT30 series turbo or smaller it will be fine.
$1k AUD for the lot.
The gate clears my stock bonnet by a good 30mm, it was designed with the hottest area is actually directly under the bonnet vent.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 14, 2012 - 4:51 PM
placham
Joined Nov 24, '10
From Worth, IL
I can vouch for 6boost, Kyle makes some great quality parts got one on my Rb20. The way he builds merge collectors is insane and everything is made out of steam pipe stronger than SUS.
Free bump, nice setup BTW GLWTS.
post Feb 16, 2012 - 2:42 AM
99gt3sge
Joined Jun 7, '11
From so cal
how much would it be shipped to california zip code 90201?
Lo-Fi Version Time is now: July 6th, 2026 - 11:09 AM
