> question regarding installing 7th gen shifter
post Feb 17, 2012 - 1:57 PM
JasonX
Joined Oct 18, '07
From Orange County, CA
When doing this mod, are you guys changing the entire shifter assembly with the 7th gen or just the shifter? thx
post Feb 17, 2012 - 2:21 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I just changed the shifter an put the back to shims in under the assembly
94 st hatch my daily driver
n
CAcelica29
Joined Aug 26, '11
From ventura, ca
just the shifter itself and the bushings that go under the assembly where the bolts go to the floor. you keep the whole plastic assembly.
post Feb 17, 2012 - 2:29 PM
JasonX
Joined Oct 18, '07
Thanks guys. I was just looking for a way to use the 7th gen metal bushings instead of the rubber ones. Also, I was talking to someone and they said shifting aggressively , pushing too hard on the shifter could cause internal damage. He said newer cars have adjustable stops. I don't think our gen has it. Thoughts?
post Feb 18, 2012 - 5:28 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
It might be easier to take the whole stock assembly out FIRST, then put in the 7th gen shifter. That made it worlds easier for me and detaching the shift cables from the assembly is easy peezy.
June '12 COTM
'95 AT200
post Feb 27, 2012 - 11:58 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
if you call TWM, you might be able to get replacement bushings.
http://www.twmperformance.com/bushingkits/index.htm
This post has been edited by Smaay: Feb 27, 2012 - 11:59 AM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 27, 2012 - 5:21 PM
trdproven
Joined Aug 2, '05
From Guam
you use BOTH the 7th gen shifter and the metal spacers.
It will be this tall.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: July 9th, 2026 - 1:29 PM
