> My test with AutoRX
post Feb 22, 2012 - 3:46 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
Backstory: My brother bought this car with 130k on it and drove it for 90k. I got it at 220 or so. He ALWAYS serviced it at the dealer.(I tried to convince him that it would be cheaper to have an independent do it, but now that I own it, I love it) Anyway, changed oil, added Auto-Rx to it and drove the 2500 miles completing the clean cycle. Initially compression was:
150,140,135,150
Now after the clean cycle, compression is:
165,165,170,170
I still have to finish the rinse cycle, but the results are pretty impressive so far. I do have to say that I switched compression gauges between the first and second tests. Each test was done twice and averaged. Regardless of actual numbers, the fact that it evened it out is impressive to me.
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
Replies (1 - 2)
post Feb 22, 2012 - 4:08 PM
mandrek
Joined May 4, '05
From western MD/NOVA
interesting.. though what is it supposed to do.. (scientifically)? is it one of those products that says that it will fill the small gaps and cracks in the metal(on the microscopic lvl), helping to smooth it out and also form a better seal?
post Feb 23, 2012 - 3:30 AM
UVZ164
Joined Sep 30, '11
From Sydney
This is what i found on their website:
Is a specially formulated, all-natural metal cleaner designed to thoroughly clean the internals of your engine.
Restores the vehicle to maximum efficiency.
Decreases oil consumption.
Reduces emissions because the ring pack is cleaned and the valves seal better.
Rejuvenates seals, resulting in reduced or eliminated leaks.
Replaces the need for oil additives and solvent flushes.
Enables the motor oil to lubricate parts more effectively.
Saves turbo bearings by liquefying high-temperature carbon deposits.
Provides residual lubricity because the cleaned components allow polar bonding of motor oil to components.
Uses oil as a carrier and liquefies all contaminants to prevent particulates from blocking the oil screen, oil pump, or piston port.
Is safe for turbo engines.
Seems a bit too good to be true since it does almost everything lol, but if it works it works
Lo-Fi Version Time is now: August 9th, 2026 - 9:59 AM
