Feb 26, 2012 - 7:05 PM
Enthusiast ![]() ![]() Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) |
New 5S time. A car-part.com search says only Celica 5S motors will fit, is that true? I need something complete and ready to go WITHOUT spending $700. PLEASE tell me 3G Cammy motors fit, I can get those CHEAP. My motor has a plethora of new parts, like timing components, water pump, and dizzy. I can swap all that over. It is just not worth it going through the trouble of pulling the motor to machine the block (apparently, my block is warped because my head was machined when I did the gasket).
Need quick answers, this motor is on borrowed time. |
Feb 26, 2012 - 7:38 PM
To my knowledge, the only difference between the Camry and Celica engines is a harmonic balancer in the Camry 5S. There might be wiring differences but if so, just reuse your Celica harness.
Feb 26, 2012 - 7:54 PM
To my knowledge, the only difference between the Camry and Celica engines is a harmonic balancer in the Camry 5S. There might be wiring differences but if so, just reuse your Celica harness. That's the answer I needed. I would need to reuse all my old sensors and such as I am obd2 anyways, but that saves me hundreds of dollars. |
Feb 27, 2012 - 10:22 AM
the Camry has a different crank shaft i think. it has a gear on it to drive the oil pump. but again im not really sure. i have only dealt with Celica 5S-FE engines.
Feb 28, 2012 - 5:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
Pm rabidtrd hell know for sure if theres a difference in the 2 hes messed with both
he had a camery with a 5s that he rebuilt right befoe he got the celica -------------------- 95 gt coupe, v6 swap weekend toy
Feb 28, 2012 - 9:21 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
smaay is right i've heard the same thing
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
| Lo-Fi Version | Time is now: August 31st, 2026 - 11:59 PM |
