> removing center cover of 7gen steering wheel, very tight help
post Mar 9, 2012 - 11:13 PM
zd1818
Joined Oct 24, '09
From New Zealand
Anyone know is there any other bolt on 7gen steering wheel? side bolts on the airbag unit are so tight, is it not possible to remove them using a screw driver? I was trying to remove the central piece and put it on my 6gen celica.
This post has been edited by zd1818: Mar 9, 2012 - 11:14 PM
Replies (1 - 3)
post Mar 11, 2012 - 7:24 PM
tankd0g
Joined Oct 4, '07
From Nova Scotia
QUOTE (zd1818 @ Mar 9, 2012 - 11:13 PM) *
I think they are the same as the trispoke wheel on a Rav4 which is a Torx head.
post Mar 12, 2012 - 11:09 AM
richee3
Joined Jun 29, '08
From Denver
I've had that issue. I had to use my T27 Torx head with a 3/8 to 1/4 adapter and use my ratchet. Worked much better than trying to use the T27 on the screwdriver.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 12, 2012 - 11:30 AM
tankd0g
Joined Oct 4, '07
From Nova Scotia
QUOTE (richee3 @ Mar 12, 2012 - 11:09 AM) *
Yeah that's how I did it as well, the heads are a pretty hard steel, they won't strip easily.
Lo-Fi Version Time is now: August 21st, 2026 - 9:06 PM
