Mar 19, 2012 - 8:46 PM
Enthusiast ![]() Joined Jun 4, '10 From Jax Beach, FL Currently Offline Reputation: 0 (0%) |
I have seen the previous thread discussing this, but my case is a little different. I am going to be running 0 guauge from the hood to the trunk of my car. I am also going to make my own battery box, but what wires am I connecting exactly? I bought a battery harness and the battery wires were cut off. I know there is a black and white cable that connects to the main fuse in my fuse box so I am assuming one of them as well as one wire to the starter? What about the alternator wire? Does the alternator wire connect to the batter, the starter or the main use block?
Harness is from a 97 celica st and the other electrical system should be from a 94 celica st |
Mar 19, 2012 - 10:17 PM
Enthusiast ![]() ![]() Joined Jul 29, '11 From chino, Ca Currently Offline Reputation: 4 (100%) |
i can help you out but i don't highly understand what you mean by cut. if you can provide a pic. man i can help you out a little bit more
Mar 19, 2012 - 10:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
on a different note im considering finding a new place for the battery back in the engine bay, i think for handling reasons, these cars are front heavy on purpose
-------------------- Mike W
Mar 20, 2012 - 6:13 PM
Where the positive battery terminal used to be, splice your 0 gauge in there. Leave the alt/starter wires where they are. Run only the 0 gauge back to the trunk, then ground in the trunk as well. You'll want to add a new ground from the trans to the chassis. It sounds more complicated than it really is
Mar 20, 2012 - 10:35 PM
Yea, if it was a simple relocation I could do it in 20 minutes.
The extra step I am having is I am using a new engine harness where the battery terminals have been cut . So what I need to know is WHAT cables run to the positive side of the battery terminal. Is it just the fuse block and starter cable? |
| Lo-Fi Version | Time is now: September 1st, 2026 - 7:07 PM |
