Mar 22, 2012 - 12:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
Hi all! i have been having an ongoing problem with my swap when driving. I get a weird hesitation/sputtering when trying to accelerate.
the problem happens more when im on the highway at a steady cruise, my AFR goes blank (reads ---) and car hesitates/sputters. when i get on the gas it stops. after recently having the car sit for about 9 days i started her up and took it for a drive, upon initial acceleration (1st and 2nd gear) car sputtered and hesitated real bad, but after the car was driven for a while it pretty much stopped. its rough initially then smooths out when car is warmed up. any ideas as to why this may be happening would be appreciated! car is running on stock waste gate pressure at the moment (8psi) IC piping seems to be ok... could it be a fueling issue? it may be leaning out. Cam (boosted185) says I just need to tune it as the pistons are SLIGHTLY larger than stock pistons when he rebuilt the motor. -------------------- |
easternpiro1 hesitation and sputtering Mar 22, 2012 - 12:00 PM
bsamps4 What fuel pump are you using? Mar 22, 2012 - 6:40 PM
malecrod Hi Matt, i know it sounds simple but make sure you... Mar 22, 2012 - 6:58 PM
x_itchy_b_x o2 sensor possibility. sounds rich to me. is it sp... Mar 22, 2012 - 10:24 PM
easternpiro1 you guys wont believe this... i got stuck on the s... Mar 22, 2012 - 11:19 PM
bsamps4 Now that is the 15amp fuse that you are referring ... Mar 23, 2012 - 10:16 AM
easternpiro1 QUOTE (bsamps4 @ Mar 23, 2012 - 11:1... Mar 23, 2012 - 10:04 PM
bsamps4 COR= circuit opening relay. Sounds like you need t... Mar 23, 2012 - 10:32 PM
easternpiro1 QUOTE (bsamps4 @ Mar 23, 2012 - 11:3... Mar 24, 2012 - 3:10 AM
bsamps4 I'm here all weekend! Mar 24, 2012 - 8:47 AM
lagos Sounds like problem with the rewired wiring harnes... Mar 25, 2012 - 11:12 AM
easternpiro1 QUOTE (lagos @ Mar 25, 2012 - 11:12 ... Mar 26, 2012 - 7:04 AM
PhoenixTech Hey Matt,
Did you get anything figured out with ... Apr 3, 2012 - 11:15 AM
easternpiro1 thanks cam! It actually stopped for a while, t... Apr 7, 2012 - 1:07 PM
PhoenixTech Hey Matt, I can't remember if I asked you this... Apr 12, 2012 - 10:39 AM
easternpiro1 nah, no cel codes, it happens when im at very ligh... Apr 13, 2012 - 8:15 AM
Stambo i have the same problem, It happens so randomly. I... Apr 13, 2012 - 1:12 PM
easternpiro1 lol im going to change spark plugs this weekend an... Apr 13, 2012 - 5:36 PM
Stambo ^^ exactly what happens to mean, the motor is stil... Apr 14, 2012 - 8:37 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 12:42 PM |
