Dec 27, 2003 - 11:02 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
Hi all, today I was driving in highway and everything was going well....when I came back in city when I arrived at first light and had to stop I took a fast look to the gauge cluster and noticed a red light so I worried and turned off the car.
Then I restarded it and no lights went on...after a while I started to run again and when I stopped again I saw the engine oil light on!! So I parked to analize the problem. I shutted off again checked the engine oil quantity and was ok, not full but ok and no oil leaks at all. I started again and no lights on but after about 10 seconds running at idle the light came ON again I noticed that if I just rev to 2k or more RPMs the light goes off so the pump at 2k + RPMs work. I thought the following possibilities: - Oil sensor not working good. - Oil pump not working - Oil pump dirty What do you thing guys???????????????? HELPPPPPPPPPPPPPPPP |
edo17982 HELP!!!!!!!!! Dec 27, 2003 - 11:02 AM
97GTinKC 2 possibilities, bad sensor or low oil pressure. I... Dec 27, 2003 - 2:24 PM
edo17982 I've to tell you some thing about my engine co... Dec 27, 2003 - 4:21 PM
DustyBurns30 what your describing sounds exactly like what happ... Dec 28, 2003 - 10:33 PM
97GTinKC Yes, I should have read your profile 1st, you may ... Dec 29, 2003 - 2:33 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 4:56 PM |
