Mar 9, 2012 - 9:38 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Hey guys,
Really getting kind of frustrated with this & would really appreciate your help; so my passenger side hub & bearing went bad a couple weeks ago & started making a lot of noise. You don't hear the noise until you reach to about 10-15 miles & up. It's like almost a banging noise & it progresses with speed. It's hard to explain the noise through text, but if you can imagine, it's like a DOOM DOOM DOOM kind of noise. Also, as I turn right or left the noise progresses more as well. I changed the hub, which was worn down to NOTHING, and also the bearing & the whole spindle and I'm still hearing the same exact noise. Now, when I changed all of that stuff, the axle nut was loose cause the nut-lock & cotter pin was missing (I don't know). So I figured since the axle nut was loose, that wore down the hub really bad. So after I changed it I thought everything would be fixed, but I guess I was wrong. I put back a nut-lock & cotter pin. Does anyone have any ideas on what else it could be? I even tried changing out my wheels to see if it were a wheel problem, but no luck. It still made the noise with new wheels. If anyone has any ideas on what it could be, your help would be much appreciated. -Thank you for your time, Ryan |
str8thugginit4ya Banging noise! Mar 9, 2012 - 9:38 PM
block worn endlink? bad ball joint? check for leaks. Mar 9, 2012 - 9:52 PM
mkernz22 your axle could be messed up as well Mar 9, 2012 - 10:08 PM
str8thugginit4ya QUOTE (mkernz22 @ Mar 9, 2012 - 11:0... Mar 10, 2012 - 1:54 PM
trdproven when you changed the axle, what about the u-joint?... Mar 11, 2012 - 7:32 AM
Bitter What did you torque the axle nut too?
What u-join... Mar 11, 2012 - 11:12 AM
808celica are you using the proper lug nuts and are they tor... Mar 11, 2012 - 12:08 PM
mak5603 You check your rear engine mount? Probably not you... Mar 11, 2012 - 12:53 PM
str8thugginit4ya Sorry for the late reply guys, I have a 94 GT w/ a... Mar 12, 2012 - 10:33 AM
schmooot Are these new parts you are putting in? (hub/beari... Mar 12, 2012 - 9:55 PM
str8thugginit4ya QUOTE (schmooot @ Mar 12, 2012 - 10... Mar 13, 2012 - 1:15 PM
Syaoran This is assuming the wheels are bigger than the co... Mar 13, 2012 - 3:00 PM
str8thugginit4ya QUOTE (Syaoran @ Mar 13, 2012 - 3:00... Mar 15, 2012 - 4:33 PM
str8thugginit4ya Ok, so sorry for taking so long with this. But I a... Mar 22, 2012 - 8:08 AM
Bitter Differential is probably shot, maybe ran out of fl... Mar 23, 2012 - 8:37 PM
str8thugginit4ya QUOTE (Bitter @ Mar 23, 2012 - 9:37 ... Mar 25, 2012 - 3:37 PM
Syaoran If you're going to get another transmission, I... Mar 25, 2012 - 4:06 PM
str8thugginit4ya QUOTE (Syaoran @ Mar 25, 2012 - 5:06... Mar 27, 2012 - 5:06 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:57 AM |
