Mar 25, 2012 - 11:39 AM
Enthusiast ![]() Joined Jun 4, '10 From Jax Beach, FL Currently Offline Reputation: 0 (0%) |
I am trying to figure out where I should start diagnosing...this issue I am having with the car. So I have a 94 ST with a 97 engine/ecu and some unknown harness. The fuel pump does not get power until the car is turned on so I have to jump for it to run when I crank the car. The car also doesnt start without the help of starter fluid and a lot of trial. Now when it does start I turn the ignition off and the car is still running, I take the key out of the ignition and the car is still running, I take the negative battery pole out and the car is still running, I take the positive battery pole off and the car still runs, I take off the EFI fuse and it still runs...Im about to remove the alternator wire, but then I think hey this may not be a good idea....so i start removing wires for the dizzy and it finally shuts off.... What a car, it starts when it wants and shuts off when it wants. I cant win here.
m2736185 Car doesnt turn off....wiring issue with fuel/injectors? Mar 25, 2012 - 11:39 AM
stephen_lee at that point id get a 94 harness and ecu and go f... Mar 25, 2012 - 9:52 PM
199celica well how long does it stay running? because the ca... Mar 26, 2012 - 10:56 AM
rave2n QUOTE (199celica @ Mar 26, 2012 - 10... Mar 26, 2012 - 11:22 AM
trdproven I agree back track and go with 94 harness and ECU. Mar 26, 2012 - 7:15 PM
199celica Haha it was what came to mind at first stop. Whoev... Mar 26, 2012 - 11:13 PM
m2736185 As much as id like to go back to a 94 harness and ... Mar 27, 2012 - 8:54 PM
199celica yeah i hear you on that. i just removed my alarm s... Mar 27, 2012 - 10:17 PM
m2736185 BTW does anyone know if there is a difference betw... Mar 29, 2012 - 10:50 PM
stephen_lee trans connections are different (auto connector ad... Apr 3, 2012 - 2:35 PM
Culpable04 wouldnT a bad COR cause a problem like this ? if t... Apr 3, 2012 - 2:48 PM
m2736185 Stephen: thanks, I guess Ill try to get a MT one t... Apr 3, 2012 - 9:49 PM
Culpable04 Circuit Opening Relay, is attached to the ECU, but... Apr 4, 2012 - 2:10 PM
m2736185 ah I know exactly what you are talking about. I re... Apr 4, 2012 - 10:29 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 10:10 AM |
