> The ''ECON'' button on the climate control, what does it exactly do ?
post Mar 26, 2012 - 2:39 AM
UndaGrwnD
Joined Dec 16, '11
From The Netherlands
as the title says: ''The ''ECON'' button on the climate control'' , what does it do exactly?
it has to do with the A/C
Replies (1 - 19)
post Mar 26, 2012 - 9:27 AM
Wintersun
Joined Jan 5, '09
From Kent, United Kingdom
It's basicly a fuel saver mode for your a/c. It doesnt run your a/c constantly, but runs it every so often.
1996 Green JDM GT4
1998 White JDM SSIII
1994 Black JDM Supra Aerotop
1994 Black JDM GT4
1999 Black UKDM SR
1996 Black UKDM ST
post Mar 26, 2012 - 4:05 PM
UndaGrwnD
Joined Dec 16, '11
Oohhh okayy thanks!
post Mar 26, 2012 - 4:29 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Correct me if I'm wrong, but I believe the ECON mode doesn't dehumidify air, it simply shoots cold air in. Never knew if I was right though.
post Mar 27, 2012 - 1:12 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
I'm pretty sure it's there for those cars that don't have the option of turning off AC when the defrost is on. It's to disable the AC compressor in order to enhance fuel mileage.
post Mar 29, 2012 - 3:15 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
is it somehow possible that the a/c pump runs at 2 speeds? because it seems to load the engine half as much as the AC button does, its really irritating off-boost it saps all the power and delays the turbo spool
Mike W
269awhp / 273ft-lbs
post Apr 1, 2012 - 12:09 AM
ricochet1490
Joined May 3, '11
From Ohio
it's the open vent I believe.... instead of recirc...
There are NOT two speeds for the A/C compressor. It's an electromagnet that turns on (electric cluctch) and is either ON or OFF. For cars with manual control you have the a/c button with which you can turn the coompressor on and off manually. With the auto climate control, you lose some features... let me explain.
With the manual control you also have the recirculate button (aka max ac) , or the button with the arrow that passes straight through (aka open vent)
These two functions, recirc and open vent, are just where the exchanger gets it's air from. If the exchanger gets its air from the outside at say 36C or 97F it has to do a lot of work to cool it off to say 20C for the inside of the car (causes the compressor to work harder.... more inefficient). with the recirculate on, it draws it's air form the inside of the car that has already been cooled, to say 30C, or 26 C so it doesn't have as large of a temperature difference to make up.
So you can choose to have the A/C on with either the air being drawn from the inside of the car, or the outside of the car....
When you have the auto climate control, the controls objective is to obtain the temperature you've set. In this case, I BELIEVE the ECON button is the "open the vent, but turn the compressor off" button. with the A/C on, it's the "a/c is on with the recirc also on" (because that is the most efficient and really the only way the A/C should ever be on from an efficiency stand point)
So in conclusion, A/c is compressor on with recirculate also on
ECON is the compressor off with the vent open to the outside to let the outside air cool the inside of the car off.
This post has been edited by ricochet1490: Apr 1, 2012 - 12:33 AM
post Apr 1, 2012 - 7:42 AM
Neon90424
Joined Jan 19, '11
why wouldnt you just roll down your window...
post Apr 1, 2012 - 9:29 AM
UndaGrwnD
Joined Dec 16, '11
why dont you walk instead of drive your car ?
post Apr 1, 2012 - 11:38 AM
Neon90424
Joined Jan 19, '11
driving is faster
post Apr 1, 2012 - 11:54 AM
richee3
Joined Jun 29, '08
From Denver
Who has an owner's manual and can look it up?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 1, 2012 - 1:53 PM
UndaGrwnD
Joined Dec 16, '11
QUOTE (Neon90424 @ Apr 1, 2012 - 6:38 PM) *
driving is faster
turning the A/C on is better wink.gif and colder
QUOTE (richee3 @ Apr 1, 2012 - 6:54 PM) *
post Apr 1, 2012 - 3:44 PM
Neon90424
Joined Jan 19, '11
i just answered why i drive instead of walk. im talking about the econ mode, its useless. seems to suck in hot air if anything, why an econ mode if u can just roll the window down
post Apr 1, 2012 - 5:11 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (Neon90424 @ Apr 1, 2012 - 3:44 PM) *
exactly -
It's just hot air being drawn in from around the car.....
unless of course it's fall or spring and the temperature outside is about 65F, making it pleasent to have the vent open in the event of rain.....
This post has been edited by ricochet1490: Apr 1, 2012 - 5:11 PM
post Apr 24, 2012 - 7:05 AM
delusionz
Joined Feb 11, '08
that doesnt seem to be the case as the recirc/vent functions work independently of the ac/econ functions, and econ still loads up the engine, just not as much as the ac button, so surely it must use the compressor atleast some of the time
Mike W
269awhp / 273ft-lbs
post Apr 24, 2012 - 10:40 AM
ricochet1490
Joined May 3, '11
From Ohio
I suppose I will have to verify that for myself when I get the RHD beams done. It will have the climate control like your guys's. I was just going off of how the ECON button worked in our Nissan. And that's how it operated.
post Apr 25, 2012 - 12:11 AM
celicaluva79
Joined Apr 6, '12
From south carolina
I wanna know where the hell yall are seeing this " econ" button at. Do all 6?gens have it
post Apr 25, 2012 - 12:12 AM
ricochet1490
Joined May 3, '11
From Ohio
auto climate control on jdm spec and some aussie spec celicas 98+
post Apr 25, 2012 - 1:37 AM
delusionz
Joined Feb 11, '08
i *think* also, econ function ties in with auto temperature control, (setting target temperature)
Mike W
269awhp / 273ft-lbs
post Apr 25, 2012 - 1:57 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (celicaluva79 @ Apr 25, 2012 - 1:11 AM) *
Not usdm's. My St204 Gt-S doesn't have this function contrary to my JDM Gt-Four. It's a JDM/RHD + Euro feature only IIRC.
This post has been edited by dudeofchaos: Apr 25, 2012 - 2:02 PM
Lo-Fi Version Time is now: September 13th, 2026 - 8:49 PM
