Mar 26, 2012 - 3:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I've recently changed out my struts with KYB Gr2's and also replaced the strut mounts all around
(mounts looked like this, but ordered kyb http://www.ebay.ca/itm/OEM-Replacement-Fro...=item2c5f3c522c ) However, in the rear, I am still getting a knocking sound in the rear, as if the struts are blown but everything is all new. Everythings been put in correctly. Is there another part that needs to be replaced when replacing the strut mounts as well? Or could there be something else causing this sound? I tried searching but nothing came up. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
jordisonjr Strut Knocking Sound Mar 26, 2012 - 3:13 PM
Spider77 The only knocking sound Ive had in the rear was my... Mar 26, 2012 - 3:40 PM
jordisonjr Are those the ones that wrap completely around the... Mar 26, 2012 - 3:49 PM
jordisonjr Bump, Any other suggestions? Mar 28, 2012 - 3:44 PM
toyotatech3 check the sway bar links Mar 28, 2012 - 4:43 PM
Redmann813 I have the same symptoms too but i thought it was ... Mar 28, 2012 - 5:11 PM
mkernz22 it's the sway bar bushings. I have the same pr... Mar 28, 2012 - 10:20 PM
jordisonjr Yea struts and moutns are new, as well as the endl... Mar 29, 2012 - 8:02 AM
mkernz22 You can't really tell anything from just looki... Mar 29, 2012 - 10:55 AM
jordisonjr Is there anything else it could possibly be either... Mar 29, 2012 - 10:59 AM
199celica not to steal your thread man but i just put in the... Mar 29, 2012 - 5:13 PM
jordisonjr No, you probably didn't line the mounts up wit... Mar 29, 2012 - 8:22 PM
bruiseboy2 I recently did the struts on my car as well and ha... Mar 29, 2012 - 8:45 PM
jordisonjr Never thought of that. Ill take a look at that as ... Mar 29, 2012 - 9:54 PM
199celica thanks jordisonjr i forgot they had to be pointed ... Mar 30, 2012 - 5:13 PM
jordisonjr No problem. Mar 30, 2012 - 10:18 PM
Galcobar The sway bar bushings are a cheap and easy item to... Mar 31, 2012 - 1:43 AM
jordisonjr Did you have similar issues with only cluncking wh... Mar 31, 2012 - 7:48 PM
mkernz22 Well I know for a fact that my clunking was becaus... Apr 1, 2012 - 12:49 PM
jordisonjr I took a look yesturday at my sway bar bushings.
T... Apr 1, 2012 - 1:44 PM
MidnightCelica202 Did you use new nuts for the strut mounts? And I ... Apr 2, 2012 - 7:32 PM
mkernz22 YOU AREN'T LISTENING TO ME. IT'S YOUR SWAY... Apr 2, 2012 - 7:48 PM
jordisonjr Midnight: Ill check that out, pretty sure I used t... Apr 4, 2012 - 12:46 PM
jordisonjr My rear bushings say 16mm. (On a 95 GTS)
Did some ... Apr 6, 2012 - 11:58 AM
hatchy_gt-s QUOTE (jordisonjr @ Apr 6, 2012 - 12... Apr 6, 2012 - 12:59 PM
jordisonjr Thanks man!
Gunna order the bushings tonight a... Apr 6, 2012 - 1:12 PM
jordisonjr Got the bushings in today, just gotta find some ti... Apr 21, 2012 - 4:18 PM
Redmann813 sweet let us know Apr 22, 2012 - 1:49 PM
jordisonjr Got the rear sway bar bushings in and it has solve... May 2, 2012 - 2:15 PM
Galcobar Always nice when it's the cheap and easy fix. May 2, 2012 - 6:08 PM
Redmann813 hell yea May 3, 2012 - 2:25 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:35 AM |
