> Strut Knocking Sound, In the rear
post Mar 26, 2012 - 3:13 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I've recently changed out my struts with KYB Gr2's and also replaced the strut mounts all around
(mounts looked like this, but ordered kyb http://www.ebay.ca/itm/OEM-Replacement-Fro...=item2c5f3c522c )
However, in the rear, I am still getting a knocking sound in the rear, as if the struts are blown but everything is all new.
Everythings been put in correctly.
Is there another part that needs to be replaced when replacing the strut mounts as well?
Or could there be something else causing this sound?
I tried searching but nothing came up.
My Celica!
- jordisonjr   Strut Knocking Sound   Mar 26, 2012 - 3:13 PM
- - Spider77   The only knocking sound Ive had in the rear was my...   Mar 26, 2012 - 3:40 PM
- - jordisonjr   Are those the ones that wrap completely around the...   Mar 26, 2012 - 3:49 PM
- - jordisonjr   Bump, Any other suggestions?   Mar 28, 2012 - 3:44 PM
- - toyotatech3   check the sway bar links   Mar 28, 2012 - 4:43 PM
- - Redmann813   I have the same symptoms too but i thought it was ...   Mar 28, 2012 - 5:11 PM
- - mkernz22   it's the sway bar bushings. I have the same pr...   Mar 28, 2012 - 10:20 PM
- - jordisonjr   Yea struts and moutns are new, as well as the endl...   Mar 29, 2012 - 8:02 AM
- - mkernz22   You can't really tell anything from just looki...   Mar 29, 2012 - 10:55 AM
- - jordisonjr   Is there anything else it could possibly be either...   Mar 29, 2012 - 10:59 AM
- - 199celica   not to steal your thread man but i just put in the...   Mar 29, 2012 - 5:13 PM
- - jordisonjr   No, you probably didn't line the mounts up wit...   Mar 29, 2012 - 8:22 PM
- - bruiseboy2   I recently did the struts on my car as well and ha...   Mar 29, 2012 - 8:45 PM
- - jordisonjr   Never thought of that. Ill take a look at that as ...   Mar 29, 2012 - 9:54 PM
- - 199celica   thanks jordisonjr i forgot they had to be pointed ...   Mar 30, 2012 - 5:13 PM
- - jordisonjr   No problem.   Mar 30, 2012 - 10:18 PM
- - Galcobar   The sway bar bushings are a cheap and easy item to...   Mar 31, 2012 - 1:43 AM
- - jordisonjr   Did you have similar issues with only cluncking wh...   Mar 31, 2012 - 7:48 PM
- - mkernz22   Well I know for a fact that my clunking was becaus...   Apr 1, 2012 - 12:49 PM
- - jordisonjr   I took a look yesturday at my sway bar bushings. T...   Apr 1, 2012 - 1:44 PM
- - MidnightCelica202   Did you use new nuts for the strut mounts? And I ...   Apr 2, 2012 - 7:32 PM
- - mkernz22   YOU AREN'T LISTENING TO ME. IT'S YOUR SWAY...   Apr 2, 2012 - 7:48 PM
- - jordisonjr   Midnight: Ill check that out, pretty sure I used t...   Apr 4, 2012 - 12:46 PM
- - jordisonjr   My rear bushings say 16mm. (On a 95 GTS) Did some ...   Apr 6, 2012 - 11:58 AM
|- - hatchy_gt-s   QUOTE (jordisonjr @ Apr 6, 2012 - 12...   Apr 6, 2012 - 12:59 PM
- - jordisonjr   Thanks man! Gunna order the bushings tonight a...   Apr 6, 2012 - 1:12 PM
- - jordisonjr   Got the bushings in today, just gotta find some ti...   Apr 21, 2012 - 4:18 PM
- - Redmann813   sweet let us know   Apr 22, 2012 - 1:49 PM
- - jordisonjr   Got the rear sway bar bushings in and it has solve...   May 2, 2012 - 2:15 PM
- - Galcobar   Always nice when it's the cheap and easy fix.   May 2, 2012 - 6:08 PM
- - Redmann813   hell yea   May 3, 2012 - 2:25 PM
Lo-Fi Version Time is now: August 4th, 2026 - 2:39 PM
