> 7A-FE Compression Ratio, Looking at changing the CR of my 7afe when I rebuild.
post Mar 30, 2012 - 12:00 AM
PaukST
Joined Mar 15, '12
From Wrightstown, NJ
Hey all, I'm trying to decide what to do with my 7AFE (have to take it apart due to a rod knock anyway). I've kicked around a few ideas (or maybe a lot rolleyes.gif ), and I'm currently researching what an increase in compression ratio might do. Does anyone have any info on this? I'm unsure of the potential difference in performance, and I can't seem to find any hard data on what pistons (4age, smallport 4age, 4agze) result in what CR. I've been trying to make sense of these tools and formulas - http://www.csgnetwork.com/compcalc.html http://s-86.com/s-cr.html and http://s-86.com/s-cr-chart.html - but I'm having a hard time digging out the relevant numbers. Doing the math myself or using the calculator I come up with significantly different numbers than their little handy chart, so I don't know what to think. Is this a futile exercise? Will I even be able to notice a performance difference over the stock 9.5:1 without having to use higher octane?
1989 Celica ST Automatic "King Cobra" -- 2005-2006
1994 Celica ST 5-speed "King Cobra II" -- 2011-????
- PaukST   7A-FE Compression Ratio   Mar 30, 2012 - 12:00 AM
- - Bitter   9.5:1 Will need cams too Tune Higher octane   Mar 30, 2012 - 7:31 AM
- - PaukST   My initial thoughts were to replace the 7AFE pisto...   Apr 2, 2012 - 2:07 AM
- - Smaay   dont bother trying to drop in 4A parts. its not wo...   Apr 2, 2012 - 11:51 AM
- - PaukST   Hm, I guess it may just be the wrong route to go f...   Apr 2, 2012 - 1:58 PM
- - stephen_lee   import performance parts . net sell "HP KITS...   Apr 3, 2012 - 2:27 PM
- - Smaay   the problem is you have a 7A-FE, that was the econ...   Apr 4, 2012 - 8:58 AM
- - PaukST   QUOTE (Smaay @ Apr 4, 2012 - 9:58 AM...   Apr 4, 2012 - 11:33 PM
- - Smaay   did you see the thread i made in the stickys? its ...   Apr 5, 2012 - 9:24 AM
- - Special_Edy   My local import machine shop charges $35 to d...   Apr 5, 2012 - 12:37 PM
|- - mandrek   QUOTE (Special_Edy @ Apr 5, 2012 - 1...   Apr 5, 2012 - 10:17 PM
|- - Special_Edy   QUOTE (mandrek @ Apr 5, 2012 - 10:17...   Apr 6, 2012 - 11:47 AM
- - PaukST   As far as I can tell, it would only take 3cc less ...   Apr 5, 2012 - 5:38 PM
- - Special_Edy   Just have it decked. Do the stock rebuild. You are...   Apr 5, 2012 - 7:43 PM
|- - richee3   QUOTE (Special_Edy @ Apr 5, 2012 - 7...   Apr 5, 2012 - 8:00 PM
- - Bitter   timing advance is similar to a compression increas...   Apr 5, 2012 - 9:41 PM
- - PaukST   Given what Smaay mentioned about the one he tore d...   Apr 5, 2012 - 10:36 PM
- - PaukST   It looks like reducing the chamber height by ~ .5m...   Apr 6, 2012 - 11:35 PM
|- - Special_Edy   QUOTE (PaukST @ Apr 6, 2012 - 11:35 ...   Apr 7, 2012 - 12:50 AM
- - celica74   Let us know what you decide to do, the progress an...   Apr 20, 2012 - 11:01 AM
|- - Special_Edy   QUOTE (celica74 @ Apr 20, 2012 - 11...   Apr 20, 2012 - 11:23 AM
|- - celica74   QUOTE (Special_Edy @ Apr 20, 2012 - 12...   Apr 20, 2012 - 2:41 PM
- - Bitter   with 15 degrees total base advance (+5 from stock)...   Apr 21, 2012 - 1:45 PM
|- - celica74   QUOTE (Bitter @ Apr 21, 2012 - 1:45 ...   Apr 22, 2012 - 9:10 PM
- - Special_Edy   Well and besides the price of higher octane, lower...   Apr 21, 2012 - 2:13 PM
- - Bitter   I think it'll turn all the way to 25 but the g...   Apr 22, 2012 - 9:29 PM
|- - Special_Edy   QUOTE (Bitter @ Apr 22, 2012 - 9:29 ...   Apr 23, 2012 - 1:35 AM
|- - celica74   QUOTE (Special_Edy @ Apr 23, 2012 - 2...   Apr 23, 2012 - 7:16 AM
- - Bitter   I found 15 deg gave me more low end actually, ther...   Apr 23, 2012 - 7:34 AM
|- - celica74   QUOTE (Bitter @ Apr 23, 2012 - 7:34 ...   Apr 23, 2012 - 8:45 PM
- - Bitter   What year is yours? I never heard knock, I monitor...   Apr 23, 2012 - 8:58 PM
|- - celica74   QUOTE (Bitter @ Apr 23, 2012 - 8:58 ...   Apr 23, 2012 - 9:48 PM
|- - celica74   QUOTE (Bitter @ Apr 23, 2012 - 9:58 ...   Apr 25, 2012 - 7:31 AM
- - Bitter   http://www.contactmagazine.com/Issue54/EngineBasic...   Apr 23, 2012 - 9:09 PM
- - Bitter   Did you set the base timing correctly and check wi...   Apr 23, 2012 - 10:44 PM
- - mandrek   umm IIRC correctly its TE1 and E1, in the dieg por...   Apr 24, 2012 - 12:19 PM
- - Special_Edy   Another thing to add- make sure your idle is 650-7...   Apr 24, 2012 - 1:21 PM
- - mandrek   indeed, and assuming that the tension on the throt...   Apr 24, 2012 - 1:38 PM
- - celica74   Ha more things to do then i thought. Ive been driv...   Apr 24, 2012 - 1:54 PM
- - Bitter   But did you have the pins jumped on a hot engine w...   Apr 24, 2012 - 9:39 PM
|- - celica74   QUOTE (Bitter @ Apr 24, 2012 - 10:39...   Apr 24, 2012 - 9:46 PM
- - Bitter   Fine, but were the pins jumped?   Apr 24, 2012 - 10:59 PM
|- - celica74   QUOTE (Bitter @ Apr 24, 2012 - 10:59...   Apr 25, 2012 - 12:01 AM
|- - Bitter   QUOTE (celica74 @ Apr 25, 2012 - 12...   Apr 25, 2012 - 7:17 AM
- - PaukST   Got my engine fully apart, I'll put up pics or...   May 1, 2012 - 12:18 AM
|- - celica74   QUOTE (PaukST @ May 1, 2012 - 1:18 A...   May 1, 2012 - 2:13 PM
- - Special_Edy   I think he meant having the block or heads milled....   May 1, 2012 - 2:28 PM
- - PaukST   QUOTE (Special_Edy @ May 1, 2012 - 3...   May 1, 2012 - 10:10 PM
- - mandrek   there are no ARP bolts/studs that fit the 7afe sto...   May 1, 2012 - 10:42 PM
|- - celica74   QUOTE (mandrek @ May 1, 2012 - 10:42...   May 1, 2012 - 11:58 PM
- - PaukST   QUOTE (mandrek @ May 1, 2012 - 11:42...   May 3, 2012 - 5:37 PM
|- - Special_Edy   QUOTE (PaukST @ May 3, 2012 - 5:37 P...   May 4, 2012 - 12:47 PM
- - mandrek   CAN you? yes. its is worth it? NO... sure you c...   May 4, 2012 - 12:35 PM
- - richee3   ^^ I love inline engines   May 4, 2012 - 1:16 PM
|- - Special_Edy   QUOTE (richee3 @ May 4, 2012 - 1:16 ...   May 4, 2012 - 2:02 PM
- - PaukST   QUOTE (mandrek @ May 4, 2012 - 1:35 ...   May 4, 2012 - 4:59 PM
- - Special_Edy   Id replace the oil pump while you have it apart. S...   May 4, 2012 - 6:53 PM
Lo-Fi Version Time is now: May 9th, 2026 - 4:20 AM
