> Straight pipe Gt-Four
post Apr 2, 2012 - 8:25 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
I wanted to know if anybody has a video or ever seen one that you can hear a straight pipe gt-four? (De-cated oem) Stock or aftermarket exhaust, it doesn't matter it's just to give me an idea. I can't seem to find a video..
I could go this way though Idk how it would sound and I don't want it to be too loud.
This post has been edited by dudeofchaos: Apr 4, 2012 - 12:04 AM
post Apr 2, 2012 - 9:57 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I wanted to know if anybody has a video or ever seen one that you can hear a straight pipe gt-four? Stock or aftermarket exhaust doesn't matter. I can't seem to find a video..
Please describe how one would have a stock straight pipe exhaust.
**** Photobucket
post Apr 3, 2012 - 7:37 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
i had mine as a 3" open down pipe, was god awful loud, then went to a 3" dump before the rear sub frame.... was even fawking louder, quiet annoying on interstate
2001 Solar yellow Lexus IS300
post Apr 4, 2012 - 12:02 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (95CelicaST @ Apr 2, 2012 - 10:57 PM) *
What I meant is de-cated stock exhaust.
post Apr 4, 2012 - 1:11 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
straight pipe refers to the straight pipe put in place of a cat convertor unit on a regular NA celica, or other cars. on a GT4 the cat convertor is part of the downpipe off the turbo. Btw I thought you already had a 3" downpipe?
Anyways the question you're really asking is how different does it sound having a 3" downpipe as opposed to the standard downpipe and I can tell you this,
Stock downpipe with cat smashed out = not so much difference
Going from stock downpipe to 3" aftermarket downpipe (complimented with a full 3" exhaust system) the difference is great, the engine is more throaty, and you hear alot more engine sounds, you also hear the difference between wastegate open&closed.
No cell phone can really do the 3s-gte justice, but here is the best run i recorded back when i had a relatively stock 3sgte with just intake and 3" downpipe and full 3" exhaust, this was with 2 oem style oval mufflers so very quiet for a 3sgte (comparatively, but yeah alot louder than what it was with stock downpipe)
http://www.youtube.com/watch?v=vJyfBDeN2lI
Mike W
269awhp / 273ft-lbs
post Apr 4, 2012 - 1:22 AM
delusionz
Joined Feb 11, '08
This is what it sounded like after custom manifold, garrett turbo, full 3" exhaust and one of those oval mufflers replaced for a resonator
http://youtu.be/jQqpEjmYvKQ
Mike W
269awhp / 273ft-lbs
post Apr 4, 2012 - 8:17 AM
95CelicaST
Joined Feb 5, '05
Straight pipe exhaust actually refers to having no cat, no resonator, no muffler. The equivalent of running open header(s) or downpipe with just a pipe extending it to the rear of the car.
Just google straight pipe exhaust and you'll see this is correct.
**** Photobucket
post Apr 4, 2012 - 1:25 PM
texasnick
Joined Feb 23, '10
From Vancouver, BC
My st205 has a 3" DP (Berk), 3" mid-pipe with 100 cell magnaflow cat, and 3" kakimoto exhaust (exhaust tip is around 700mm I think...very big).
I don't have sound clips but I can tell you that it's loud as hell.
I set off this one guy's car alarm in my parking garage every time I start it up. Not revving it, just cold idle.
I also have a tendency to set off car alarms of people parked on the side of the street if I give it more than about 50% throttle.
Exhaust pops quite nicely when off and then back on throttle.
Very throaty sound. I like it, but it gets a bit old after a while when you just want to go from A to B.
The difference in (apparent) power is definitely there. The turbo spools so much faster than with the stock dp/cat/exhaust.
I do not have boost creep issues.
Edit: There is a russian video on youtube that lets you hear the exhaust from an st205 (kakimoto)....just search kakimoto st205.
This post has been edited by texasnick: Apr 4, 2012 - 1:26 PM
post Apr 5, 2012 - 11:41 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
I didn't know the cat was part of the down pipe. But what I really wanted to know was how it would sound with no cat, no res, no nothing but a 3'' muffler.
Lo-Fi Version Time is now: August 21st, 2026 - 10:36 PM
