> WTB: Toyota Celica, Oregon or Washington
post Apr 9, 2012 - 9:59 PM
indesign
Joined Mar 21, '12
From Oregon
Hello folks,
I'm out on the lookout to buy a straight 6gen Toyota Celica, 96+ would be nice, but 94 is okay as well. GT/liftback trim in manual transmission only.
Expanding this search onto this forum because I'm not getting many results on autotrader and craigslist. Oregon and Washington only please.
Certainly willing to match bluebook values and pay extra for any reasonable modifications. Must be clean title.
Thank you
This post has been edited by indesign: Apr 9, 2012 - 10:00 PM
Replies (1 - 13)
post Apr 9, 2012 - 10:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
Should try looking on Ebay and local sales papers/bulletins if you aren't already. Best of luck to you.
2001 Miata LS 5-speed
post Apr 9, 2012 - 11:02 PM
indesign
Joined Mar 21, '12
From Oregon
Several for sale around here, but mainly ST, coupes and convertibles. And a GT hatch i went and checked out this past weekend only to see massive bondo work on a "clean title" car. I've been looking since last november. Has been disappointing.
post Apr 10, 2012 - 1:18 AM
Box
Joined Feb 23, '12
From Warrior, AL
Sorry to hear that. ST isn't that bad. Only real advantage to the GT is disc brakes on the rear, but can add those to a ST with a little work. I don't feel the extra 20-30 hp depending on year justifies the drop from 28-29/34-35 to 22/28-29(original EPA ratings). The GT also weighs almost 200 pounds more(ST versus GT liftbacks anyway). I have a ST and am very pleased with it. Just something you might want to consider.
post Apr 12, 2012 - 7:27 PM
indesign
Joined Mar 21, '12
From Oregon
Although the EPA differences are notable, I'd definitely prefer the 5s over the 7a. I only drive 5 miles to work on 3-4 day compressed shifts, so mpg isn't too big of a deal. Used to have a 95 honda civic with a factory rating of 95 hp. Must say it was definitely hard to go up hills. So I'd like to have the extra horses.
post Apr 12, 2012 - 8:25 PM
Box
Joined Feb 23, '12
From Warrior, AL
Horsepower isn't the problem there, it's torque. ST Celica makes 115 ft lb at 2,800 rpm, versus the Civic which made around 98 ft lb at 5,000 rpm. GT Celica makes 145 ft lb at 4,400 rpm. So about equal staying in the lower rpm bands with the Celica. Use mine for going up a steep mountain all the time. If you'd ever want to go and do an engine swap, the GT would be the way to go though.
post Apr 14, 2012 - 10:32 AM
Lenny
Joined Nov 2, '09
From Tacoma, Wa.
this is at a dealership. it says 1.8L 5spd but it's got disc brakes in the rear
http://seattle.craigslist.org/see/ctd/2953535494.html
here's another one
http://seattle.craigslist.org/est/cto/2954473007.html
1994 Celica GT- TenzoR 1.8in. Drop springs. 16mm wheel spacers.
post Apr 15, 2012 - 8:19 PM
SoundSlut_dotcom
Joined Feb 16, '03
QUOTE (indesign @ Apr 9, 2012 - 8:59 PM) *
Hello folks,
Thank you
post Apr 20, 2012 - 4:28 PM
indesign
Joined Mar 21, '12
From Oregon
Okay, I've found a Celica.
Moderators, please erase this thread. Thanks.
post Apr 23, 2012 - 11:14 AM
mak5603
Joined Oct 20, '08
QUOTE (Box @ Apr 9, 2012 - 11:18 PM) *
That's not true. The GT is also a direct swap for 3sgte, and how many st's got power stuff? And the brakes.. and the 5s.. 20-30 HP is a lot when you only make 90-130..
2014 Toyota Rav4 XLE
post Apr 23, 2012 - 11:28 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (mak5603 @ Apr 23, 2012 - 11:14 AM) *
He has a point there.
Majority of STs do not come with the power options, including sunroof etc etc. My ST was all power, excluding sunroof but it was obvious these were the options choosen at the dealership for more $$$..gold useless emblems and all.
After recently riding in a ST after a long time out of one, they certainlly have their pros & cons vs. the GT.
For instance, the ST has quite the better low end torgue requiring less reving to get to the power, though it does not have the extra power on demand persay. Where as the ST would lack at highway speeds in passing, the GT flys by without hesitation. The GT I believe has stiffer/thicker sway bars.
The simplicity of a swap is certainlly there with the GT, but whats an extra mount with a poly insert going to cost...less then a hundred used so the viablity to that argument only lies with the harness conversion, which most send off to get done anyway. I can't recall if the lower crossmember is the same, but last time I viewed it, appears identical.
few other tidbits like shift cables, and rad...list goes on...either or are a good platform, just require research for the end goals. Having both in hand at one point, has assisted quite a bit for the sake of dialog.
post Apr 23, 2012 - 12:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
I mentioned the part about swapping in a later post. tongue.gif My ST is fully loaded. Personally could do without the power options and sunroof. I like manual windows, don't have to worry about regulators and motors going out. Having long hair I'll never use the sunroof, would arrive at my destination with a giant knot... For me I just can't justify having another 20-30 hp for that horrendous of a drop in fuel economy. If I wanted 22/28 I'd just get a 240SX and call it a day.
post Apr 23, 2012 - 1:15 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I have an old friend up by me selling a 94 GT on the cheap. All power options - 124K miles. I haven't looked at it yet, but I imagine its all in good shape. The clutch went out and he can't afford to fix it.
Figure $300 and change for a South Bend clutch, and you have yourself an all-option 94 Celica GT. I wouldn't pay his asking price ($3,000) but I was thinking if it was in good shape I'd buy it, fix it, then sell it.... or perhaps keep it for a Daily Driver.
(I'm in the Seattle area, BTW)
**** Photobucket
post Apr 23, 2012 - 1:21 PM
97lestyousay
Joined Jul 7, '03
he found one, he just didn't put completed in the subtitle.
This post has been edited by 97lestyousay: Apr 23, 2012 - 2:45 PM
JDM guy made me do it.
Lo-Fi Version Time is now: July 8th, 2026 - 5:49 AM
