Apr 20, 2012 - 7:09 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I'm in the market for an e-153 lsd transmission. After doing some searching on this site, and some searching on the web I've gotten myself confused. I've heard a lot of members say that they preferred the e-153 out of the Solara due to the newer better bearings, but after searching around online it came to my attention that the Solara's were not available with the limited slip, and that i would have to buy the LSD separate and install it. Is this true? What about the v6 camry? Is that non-lsd as well? It would be pointless for me to go through all of this conversion crap just to get a non-lsd transmission.
bsamps4 E-153 transmission Apr 20, 2012 - 7:09 AM
Special_Edy I think the Turbo MR2 is the only one with factory... Apr 20, 2012 - 9:38 AM
bsamps4 Would it really be that much more? Because then I ... Apr 20, 2012 - 9:51 AM
Culpable04 the amount of work = cost of an LSD diff to swap i... Apr 20, 2012 - 10:32 AM
bsamps4 I would have to get the shift linkage from a Camry... Apr 20, 2012 - 6:47 PM
Special_Edy QUOTE (bsamps4 @ Apr 20, 2012 - 7:47... Apr 20, 2012 - 8:18 PM
Smaay QUOTE (Special_Edy @ Apr 20, 2012 - 6... Apr 21, 2012 - 9:38 AM
Special_Edy QUOTE (Smaay @ Apr 21, 2012 - 9:38 A... Apr 21, 2012 - 8:03 PM
bsamps4 QUOTE (Special_Edy @ Apr 21, 2012 - 8... Apr 21, 2012 - 11:52 PM
bsamps4 I know that it has to be removed and replaced by a... Apr 21, 2012 - 7:59 AM
mkernz22 I thought the GT4 shift linkage just fits right on... Apr 21, 2012 - 8:06 AM
bsamps4 Yes it does, but I was under the impression that t... Apr 21, 2012 - 8:23 AM
mkernz22 QUOTE (bsamps4 @ Apr 21, 2012 - 9:23... Apr 21, 2012 - 8:46 AM
96stgreendemon Changing the differential out in the E-153 is not ... Apr 21, 2012 - 8:26 AM
bsamps4 QUOTE (96stgreendemon @ Apr 21, 2012 - 8... Apr 21, 2012 - 9:31 AM
stephen_lee if you get a factory LSD its MUCH harder to source... Apr 21, 2012 - 7:42 PM
Smaay ^^^ i know exactly what he is trying to do, im spe... Apr 21, 2012 - 11:41 PM
Smaay no ill feelings, just explaining whats going on Apr 22, 2012 - 9:34 AM
Special_Edy QUOTE (Smaay @ Apr 22, 2012 - 9:34 A... Apr 22, 2012 - 5:46 PM
Culpable04 I used the shift linkage from a AWD trans.
and s... Apr 22, 2012 - 2:20 PM
OOBE QUOTE (Culpable04 @ Apr 22, 2012 - 12... Apr 29, 2012 - 10:34 PM
Culpable04 I'll take my cheap-ness as a compliment, I thi... Apr 30, 2012 - 2:01 PM
96stgreendemon Having an lsd trans can be done for under $40... Apr 30, 2012 - 2:30 PM
bsamps4 Culp I want an LSD for 200 bucks!!!... May 2, 2012 - 2:49 PM
Ted95 QUOTE (bsamps4 @ May 2, 2012 - 3:49 ... May 2, 2012 - 11:07 PM
Smaay that would require longer cables and linkage that ... May 3, 2012 - 12:18 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 11:22 AM |
