> Changing spark plugs on a Gt-Four/removing IC, The IC is kinda..... in the effin' way.
post Apr 30, 2012 - 6:55 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
I was just wondering how do you change the plugs on an St205? I know the IC has to go, but do you have to purge it to remove it or you can simply remove it and the coolant will stay inside?
After that I guess it's not that hard... remove the bolts holding it in place and remove the clamps on the TB and on the turbo and you can easily access the plugs and wires.
Lo-Fi Version Time is now: September 15th, 2026 - 4:34 PM
