May 1, 2012 - 11:25 PM
Enthusiast ![]() Joined Apr 6, '12 From south carolina Currently Offline Reputation: 2 (100%) |
Just wanted to see some dash kit pics. Im debating which would go better with my silver celi...silver carbon fiber or brushed aluminum?
May 2, 2012 - 12:11 AM
I am thinking about possibly using the 3M 1080. Thinking anthracite carbon fiber or brushed steel would look cool. Supposedly can get free samples, looking into that now.
This post has been edited by Box: May 2, 2012 - 12:12 AM -------------------- 2001 Miata LS 5-speed
May 2, 2012 - 12:34 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
I personally dont see the reason on buying kits when you can usually get sheet vinyl cheaper and do it yourself, like Box was saying.
example of mine: ![]() its 3M 1080 Woodgrain, bought from TopVinylFilms when you buy it all you need is -an exacto knife -the vinyl -a heat gun -patience do it -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
May 2, 2012 - 12:43 AM
http://solutions.3m.com/wps/portal/3M/en_U...RequestSamples/
I did it as an installer, less info to fill. Under company name I put self employed, and preferred distributor put Amazon. At least that way am honest about it. -------------------- 2001 Miata LS 5-speed
May 2, 2012 - 12:51 AM
Glad you posted smkr3w, I have a question. On the edges where you folded the material over, how'd you go about that exactly to get it smooth? Did you do like a star cut on the material to get it to fold better?
May 2, 2012 - 12:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
May 2, 2012 - 12:57 AM
is that silver carbon fiber or reg?^^^^^
May 2, 2012 - 1:57 AM
Glad you posted smkr3w, I have a question. On the edges where you folded the material over, how'd you go about that exactly to get it smooth? Did you do like a star cut on the material to get it to fold better? I only star cut on the clock and hazard light holes.. the rest I used a heat gun and pulled taught like i was trying to wrap the back of it as well and then trimmed leaving about a 1/4-1/2 inch excess all around. Patience and a heat gun really is the key to a nice edge. also and the more square corners like around the radio/climate i used a single cut (45 degrees or so) close to the corner. however on the shifter surround after i took these pics the corner curve nearest the dash on the pass side started to lift a little do to the arizona heat so i trimmed an even inch around the base making somewhat parallel lines -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
May 2, 2012 - 2:12 AM
Thanks for the info!
May 2, 2012 - 4:44 AM
Enthusiast ![]() Joined Dec 18, '11 From Honolulu, HI Currently Offline Reputation: 3 (100%) |
anyone have a site where I can buy dash kits?
May 2, 2012 - 11:43 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Ebay
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 2, 2012 - 6:08 PM
May 3, 2012 - 1:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
MIMOUSA.com
-------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
| Lo-Fi Version | Time is now: May 7th, 2026 - 7:19 AM |
