> 00+ gts brake swap an abs delete, wheres the links / write ups
post May 4, 2012 - 5:45 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok now that the 1mz is running up to par i want to focus. On the brakes.
I want to delete. The abs an swap the front brakes to the newer gts brakes
Im looking for the links on hows there done so i can do mine
I tried to search but my phone sucks
Thank for the help as alway
94 st hatch my daily driver
n
3 Pages V   1 2 3 >
Replies (1 - 19)
post May 4, 2012 - 5:52 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Make sure you document this as well. Once my swap is done I want to do the ABS delete as well.
post May 4, 2012 - 6:30 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I plan on it
n
post May 4, 2012 - 9:03 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
why do you want the newer gts brakes??
post May 4, 2012 - 9:26 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
My understanding was they are better than our stocks
n
post May 4, 2012 - 10:11 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (kurt95gt @ May 4, 2012 - 9:26 PM) *
you mean the caliper??? the rotors are the same size as our gt's. Ok maybe the gt-s are 5mm larger in diameter.
post May 4, 2012 - 10:40 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
So not not really worth doin on my gt then
n
post May 4, 2012 - 10:46 PM
Box
Joined Feb 23, '12
From Warrior, AL
Want to say 7th gen caliper is dual pot, where our's are single pot. Unless it was a ST202 or ST205, they were dual pot too I believe.
2001 Miata LS 5-speed
post May 4, 2012 - 10:53 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ill have to look more into it
n
post May 4, 2012 - 11:53 PM
Ted95
Joined Mar 8, '09
From Westport, MA
ive read somewhere about the gts brakes and that they really werent much of an upgrade as they were pretty similar to the stock gt brakes.
this is a write up on how to convert mr2 calipers for a gt
http://www.6gc.net/forums/index.php?showto...+brake+calipers
st205 powered ss3 coupe
post May 5, 2012 - 12:04 AM
Box
Joined Feb 23, '12
From Warrior, AL
Got to looking at parts. Seems 7th gen Celica is single pot too. It's the MR2 Turbo that had dual pot calipers, along with the ST202 and ST205 if I recall correctly. I think I remember something on here about someone using MR2 Turbo calipers.
This post has been edited by Box: May 5, 2012 - 12:05 AM
post May 6, 2012 - 1:20 AM
BonzaiCelica
Joined Apr 24, '08
mr2 have less surface area than the oem gt calipers. get supertrut celica twin piston calipers. They supposedly bolt up too gt brake bracket.... says forgmann via his forsale thread. but pics are that clear (night pics)
This post has been edited by BonzaiCelica: May 6, 2012 - 1:20 AM
post May 6, 2012 - 10:22 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (BonzaiCelica @ May 6, 2012 - 1:20 AM) *
They make no difference, per Rusty and S8S8. Bit of a waste of cash unless your car is a track car.
This post has been edited by richee3: May 6, 2012 - 10:23 AM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 6, 2012 - 3:24 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (richee3 @ May 6, 2012 - 11:22 AM) *
yes true that better surface area! less likely to lock up your brakes on the TRACK!!
post May 6, 2012 - 3:43 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ive done my best with this car to keep the major parts from other usdm cars so if/when they need replaced i can just walk in to advance an say i need — part for —car
So the ss-iii calipers are out of the running
Ill probably just stick with the gt brakes an delete the abs if i cant get my brakes to work better after i bleed them again
n
post May 6, 2012 - 8:09 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (kurt95gt @ May 6, 2012 - 3:43 PM) *
ABS delete is fairly simple (from talking to others who have done it) just a few new brake lines along the firewall which can be ordered from toyota.
I am converting my car from ABS to no-ABS in the next month or so, I just got all the firewall lines from a parts car that didn't have ABS.
post May 6, 2012 - 8:37 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Could you post up some of the info you know in alittle better detail?
n
post May 6, 2012 - 8:53 PM
Why are you getting rid of ABS?!??!?
post May 6, 2012 - 9:03 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (kurt95gt @ May 6, 2012 - 8:37 PM) *
Yea I'll snap some pics and write some more tomorrow
QUOTE (playr158 @ May 6, 2012 - 8:53 PM) *
For me its because all my sensors are toast, and I want a cleaner engine bay
post May 6, 2012 - 9:22 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
My abs box hasnt kicked on since i done my swap so my brakes are soft
Im hoping new pads rotors an deleting the abs will fix it
n
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: August 25th, 2026 - 9:21 AM
