May 7, 2012 - 5:02 PM
Enthusiast ![]() Joined Apr 6, '12 From somewhere Currently Offline Reputation: 0 (0%) |
for some reason im always confused about where to place the jack stands i just wanna be safe and i dont wanna cause any damage to the car, so i need to know where is the safest and the best spot to place the jack stands(front end)?
mindkiller jack stands points May 7, 2012 - 5:02 PM
trdproven usually hard stable areas. even same places as th... May 7, 2012 - 6:24 PM
Special_Edy QUOTE (mindkiller @ May 7, 2012 - 5... May 7, 2012 - 8:14 PM
mindkiller QUOTE (Special_Edy @ May 7, 2012 - 8... May 8, 2012 - 1:23 AM
trdproven the cross member is heavily used by many. in fact... May 8, 2012 - 6:12 AM
rave2n I use the side points right under the doors when I... May 8, 2012 - 7:20 AM
Special_Edy QUOTE (rave2n @ May 8, 2012 - 7:20 A... May 8, 2012 - 9:30 AM
rave2n QUOTE (Special_Edy @ May 8, 2012 - 10... May 8, 2012 - 9:52 AM
Special_Edy QUOTE (rave2n @ May 8, 2012 - 9:52 A... May 8, 2012 - 11:07 AM
playr158 QUOTE (rave2n @ May 8, 2012 - 10:52 ... May 8, 2012 - 10:56 AM
rave2n "jack in another key location"
Doesn... May 8, 2012 - 11:17 AM
Special_Edy Lol actually my first post with your post as a quo... May 8, 2012 - 11:47 AM
playr158 you can put the jack in the rear spot....jack it u... May 8, 2012 - 1:30 PM
mindkiller Thanx everyone for the replay, i wont be able to p... May 8, 2012 - 3:06 PM
Special_Edy Place the jack under the suspension crossmember, a... May 8, 2012 - 3:26 PM
mindkiller QUOTE (Special_Edy @ May 8, 2012 - 4... May 8, 2012 - 5:18 PM
trdproven good luck with the rear engine mount replacement ... May 8, 2012 - 5:49 PM
mindkiller QUOTE (trdproven @ May 8, 2012 - 5:4... May 8, 2012 - 5:57 PM
rave2n QUOTE (mindkiller @ May 8, 2012 - 5... May 8, 2012 - 6:32 PM
mindkiller QUOTE (rave2n @ May 8, 2012 - 7:32 P... May 8, 2012 - 7:04 PM
Special_Edy QUOTE (mindkiller @ May 8, 2012 - 5... May 8, 2012 - 8:39 PM
rave2n QUOTE (Special_Edy @ May 8, 2012 - 9... May 8, 2012 - 9:44 PM
trdproven i took out the engine crossmember, loosened the su... May 8, 2012 - 10:42 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 3:19 PM |
