> strut inserts, how do they work
post May 9, 2012 - 7:09 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok i got a simple question
how do you install strut inserts?
i havent bought a pair yet but im planning on getting the stagg struts here kinda soon an justt want some heads up on how to install them
Sorry for such a noob question guys
But i tried to search it an found nothng an i asked richee3 an he wasnt real sure eather
94 st hatch my daily driver
n
post May 9, 2012 - 7:32 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Its pretty straight forward really. Its best to have a bench vice, in my experience it really helps. There is a flat nut of sorts that retains the inserts, put the strut assembly in the vice and use ford wrench (or some channel locks) and unscrew the retainer. Remove insert. Assembly is opposite of removal. Im sure somewhere on here is a write up for this.
post May 9, 2012 - 7:41 PM
you can buy the whole sealed unit!
post May 9, 2012 - 7:46 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
All the staggstruts i seen the fronts were inserts
The only think i found on here mentioned cutting the top off the old strut an sliding the inserts in
I didnt know if that was right or not
n
post May 9, 2012 - 7:55 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (kurt95gt @ May 9, 2012 - 7:46 PM) *
I didnt do any cutting with my stagg struts.. I just unscrewed it and swapped em out. It was a little fussy at first but a good budge and it twisted off. I used two vise grips and had a buddy's help
post May 9, 2012 - 8:02 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Good to know
Thanks guys
n
post May 9, 2012 - 8:13 PM
smkr3w
Joined Nov 29, '10
QUOTE (kurt95gt @ May 9, 2012 - 8:02 PM) *
Good to know
Thanks guys
No problem, did a quick little how to in my thread about stagg
http://www.6gc.net/forums/index.php?showto...82445&st=20
again I'm no expert or that savvy with suspensions, it's just how i did it..
post May 9, 2012 - 8:22 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Sweet thanks again
n
post May 10, 2012 - 3:29 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
one thing I never got a definate answer on : what type of oil do we use to fill in the cartridge slot once we put in the new strut insert...
anyhow some pics for your liking :
using a vice is much better
post May 10, 2012 - 4:29 AM
smkr3w
Joined Nov 29, '10
that's one thing i forgot to grab before i did my struts were gloves.. my hands were black for days.
post May 10, 2012 - 4:27 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Fill the inserts??
n
post May 10, 2012 - 4:54 PM
smkr3w
Joined Nov 29, '10
QUOTE (kurt95gt @ May 10, 2012 - 5:27 PM) *
Fill the inserts??
There's a lubrication type fluid inside the front struts.. I lost quite a bit in my driver's side since that was my first one. My passenger side I knew what to look for so I kept it upright removed the stock one slowly. And when I put in the Stagg strut the fluid slightly over filled but kept as much as possible.
I'm not sure what the fluid is tho'
post May 10, 2012 - 5:12 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok
n
post May 10, 2012 - 10:48 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Lightweight oil -- motorcycle fork oil will work though it's pretty expensive.
While it helps with heat transfer, check the instructions included with the replacement inserts. Some specifically state it's not required.
post May 10, 2012 - 11:33 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Thanks for all the info guys
I really thought this was going to get flamed
n
post May 12, 2012 - 3:20 AM
smkr3w
Joined Nov 29, '10
QUOTE (kurt95gt @ May 11, 2012 - 12:33 AM) *
Lol, I sort of felt the same way before I bought them thumbsup.gif I wanted to ask the same questions but decided to just go for it..
This post has been edited by smkr3w: May 12, 2012 - 3:20 AM
Lo-Fi Version Time is now: August 26th, 2026 - 5:54 AM
