> [5S-FE] Syaoran's Build, Update August 14!
post May 10, 2012 - 10:16 AM
Syaoran
Joined Jan 4, '12
From US
So I've bought myself a 1994 GT, black, with NONE of the extra cool stuff (sunroof, foglights, cruise control, automatic climate, 8-speaker etc)...... but who needs that? It's all just extra weight! Here's the background:
The car was bought from a fellow University Student who sold it because there was an issue with the car he couldn't solve. The issue apparently was both a bad (brand new) distributor and a bad ECU that was losing sync every 5 or less seconds.
It is in pretty bad cosmetic shape and had some massive 18 inch wheels running 225/40/18 way-oversized tires. The brakes are bad, and it seems the wheel bearings on it are going. It has a pretty bad oil leak (it's not burning it however) right around the cam cover. Seems like the timing belt is wet in oil, and so is the axle boot below, and part of the engine around there. The other side of the engine is completely fine, bone-dry, however.
With that said, it's got a working A/C, good-shape Transmission (it's an upgrade from my previous S53!), overall-good shape engine, turns on fine, the hatch struts work fine, has no interior rust holes, etc. It's pretty good.
I bought it for $1300!
With that said, I started working on a list of priorities and started tackling all the issues to get it up and running. First up was the issue of losing sync. Got rid of it by getting a new alternator from Advance Auto under warranty (saved $145! let's hope it lasts a bit) and I also got a MegaSquirt-II EMS installed. The car is no longer losing sync and idled like a purring kitten.
Next up was the brakes. I might need to get new brake lines because the rear passenger side brake line didn't pour out any brake fluid when I removed the calipers. All others poured at least a little. Might have to check what's going on... Maybe it's air trapped in the lines.
I removed the rotors to get the turned, and the calipers to get them cleaned and painted. I chose a copper-orange metallic color for them.
Once that's done, I'm putting the wheels back and getting it to my mechanic to have the oil leak fixed and likely giving it a cam-side tune up (waterpump, tensioner, idler, cam seal, crank seal and timing belt) and I will change the valve-cover gasket with plug tube seals.
Next up is getting new wheels because those 18s are WAY too damn big. Getting BBS RX 16x7" +42 in 5x114.3. I'm buying a set of 20mm front and 25mm rear spacer adapters which are double hub-centric. (54.1mm to 67.1mm). Tires will be 205/50/16 stock size. After that, I'm taking it in to the bodyshop to get the exterior quoted for fixes.
I'll keep this thread updated. I will upload some pictures soon enough!
This post has been edited by Syaoran: Aug 14, 2014 - 1:27 PM
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
- Syaoran   [5S-FE] Syaoran's Build   May 10, 2012 - 10:16 AM
- - Xander_X   If you had a break in your lines you'd notice ...   May 10, 2012 - 10:51 AM
- - Ehrgeiz   Our Celi's can easily take 18's!   May 10, 2012 - 11:55 AM
- - RabidTRD   Any pics?   May 10, 2012 - 12:38 PM
- - Syaoran   QUOTE (Xander_X @ May 10, 2012 - 11...   May 10, 2012 - 2:15 PM
- - Xander_X   Wouldn't know what language to translate it to...   May 10, 2012 - 4:39 PM
|- - Syaoran   QUOTE (Xander_X @ May 10, 2012 - 5:3...   May 11, 2012 - 2:30 AM
- - Box   Damn, that's rough. Makes me sick, someone ha...   May 11, 2012 - 2:44 AM
|- - Syaoran   QUOTE (Box @ May 11, 2012 - 3:44 AM)...   May 11, 2012 - 2:56 AM
- - Box   Nice looking rims, should look great on the Celica...   May 11, 2012 - 3:41 AM
|- - Syaoran   QUOTE (Box @ May 11, 2012 - 4:41 AM)...   May 11, 2012 - 3:50 AM
- - Xander_X   Symptoms of a bad valve are what your showing, one...   May 11, 2012 - 9:50 AM
|- - Syaoran   QUOTE (Xander_X @ May 11, 2012 - 10...   May 11, 2012 - 11:12 AM
- - Xander_X   Well the caliper is going to have fluid in it eith...   May 11, 2012 - 11:20 AM
- - Syaoran   I'll check everything when I start working on ...   May 11, 2012 - 11:38 AM
- - Syaoran   For those of you who may have stuff to sell, here ...   May 11, 2012 - 1:00 PM
- - Syaoran   Update: I might have a change of mind and get some...   May 11, 2012 - 4:53 PM
- - richee3   Just for reference, in case you need it later, her...   May 11, 2012 - 6:35 PM
|- - Syaoran   QUOTE (richee3 @ May 11, 2012 - 7:35...   May 11, 2012 - 6:54 PM
- - Syaoran   Got the wheels above. Will get some pics hopefully...   May 11, 2012 - 10:09 PM
- - Syaoran   As promised:   May 12, 2012 - 1:50 PM
- - SwissFerdi   Nice. Those are good-looking wheels.   May 12, 2012 - 8:34 PM
- - Syaoran   Thanks! Now Im in search of some center caps t...   May 13, 2012 - 8:42 AM
- - Arsaces   Should consider plasti-dipping the rims   May 13, 2012 - 9:15 AM
|- - Syaoran   QUOTE (Arsaces @ May 13, 2012 - 10:1...   May 13, 2012 - 9:58 AM
- - Syaoran   Oh I also forgot to add, the brakes /seem/ to be f...   May 13, 2012 - 10:20 AM
- - richee3   I just got around to editing that post with the pr...   May 13, 2012 - 11:47 AM
- - Syaoran   So I finally moved the car, and it seems there is ...   May 14, 2012 - 8:51 AM
- - Syaoran   Performed all tests to try and rule out the brake ...   May 14, 2012 - 4:04 PM
- - 6gcpr   Your car is coming out good man, love the wheels y...   May 15, 2012 - 9:50 AM
- - Syaoran   Thanks! I bought the brake master cylinder, go...   May 15, 2012 - 11:00 AM
- - Syaoran   So I've stumbled upon a couple of issues going...   May 23, 2012 - 10:24 PM
- - Syaoran   I think I'm due for an update, so here goes. ...   Jun 2, 2012 - 2:10 PM
- - Syaoran   I had run into more issues. The MS-II really hates...   Jun 19, 2012 - 12:20 AM
- - taibones   i first saw the pic of your car with those wheels ...   Jun 19, 2012 - 1:55 AM
|- - Syaoran   QUOTE (taibones @ Jun 19, 2012 - 2:5...   Jun 19, 2012 - 3:16 PM
- - taibones   the center bore of the rim should be 57.1mm the ce...   Jun 19, 2012 - 3:57 PM
|- - Syaoran   QUOTE (taibones @ Jun 19, 2012 - 4:5...   Jun 19, 2012 - 4:16 PM
- - taibones   im pretty sure they are vw rims, which have a 57.1...   Jun 19, 2012 - 9:51 PM
|- - Syaoran   QUOTE (taibones @ Jun 19, 2012 - 10...   Jun 20, 2012 - 1:14 PM
- - kurt95gt   Think he means their specs are for a aftermarket r...   Jun 20, 2012 - 1:32 PM
|- - Syaoran   QUOTE (kurt95gt @ Jun 20, 2012 - 2:3...   Jun 20, 2012 - 1:43 PM
|- - taibones   QUOTE (kurt95gt @ Jun 20, 2012 - 1:3...   Jun 20, 2012 - 3:03 PM
|- - Syaoran   QUOTE (taibones @ Jun 20, 2012 - 4:0...   Jun 21, 2012 - 10:33 PM
|- - Syaoran   QUOTE (taibones @ Jun 20, 2012 - 4:0...   Aug 22, 2012 - 12:48 PM
- - taibones   yeah i have been looking for a center cap to use a...   Jun 22, 2012 - 11:15 AM
- - Edser   QUOTE (Syaoran @ May 10, 2012 - 11:1...   Jul 11, 2012 - 7:56 AM
- - Syaoran   Euro-specs come with so many cool things like the ...   Jul 11, 2012 - 1:23 PM
- - 6gcpr   any new pics to see how its coming? you fix your b...   Jul 11, 2012 - 1:41 PM
- - Syaoran   Update: New struts are in for all four corners. H...   Aug 1, 2012 - 5:21 PM
- - ricochet1490   Sounds like you've had one problem after anoth...   Aug 1, 2012 - 6:22 PM
|- - Syaoran   QUOTE (ricochet1490 @ Aug 1, 2012 - 7...   Aug 1, 2012 - 7:25 PM
- - ricochet1490   Why not get a stock ecu that functions?   Aug 1, 2012 - 7:32 PM
|- - Syaoran   QUOTE (ricochet1490 @ Aug 1, 2012 - 8...   Aug 1, 2012 - 9:08 PM
- - Syaoran   Wideband installed (Innovate LC-1), now to do some...   Aug 20, 2012 - 11:20 AM
- - Syaoran   Wish I could upload pics from my HTC Wildfire... ...   Aug 21, 2012 - 4:39 PM
- - Syaoran   Compression tested the engine, here are the result...   Aug 25, 2012 - 4:59 PM
- - Syaoran   Changed oil today... decided to take this pic (unr...   Aug 26, 2012 - 4:32 PM
- - 6gcpr   That's one fanta orange looking bumper you got...   Sep 7, 2012 - 12:07 AM
- - Syaoran   no longer orange and now on the car! pics soon...   Sep 8, 2012 - 5:51 AM
- - Edser   Still waiting for those pics!   Oct 10, 2012 - 12:56 PM
|- - Syaoran   QUOTE (Edser @ Oct 10, 2012 - 1:56 P...   Oct 11, 2012 - 2:04 PM
- - Syaoran   Here's one I took a couple hours ago. Car is s...   Oct 11, 2012 - 8:23 PM
- - Edser   Hey that bumper looks good! Face lift version...   Oct 14, 2012 - 5:07 PM
|- - Syaoran   QUOTE (Edser @ Oct 14, 2012 - 6:07 P...   Oct 14, 2012 - 7:09 PM
- - Edser   Yup! The younger the better! I'm aimin...   Oct 14, 2012 - 7:49 PM
- - Syaoran   Definitely keeping the black... It's such a un...   Oct 15, 2012 - 2:37 PM
- - Edser   I have been tempted by dark metallic brown. I don...   Oct 16, 2012 - 6:12 PM
|- - Syaoran   QUOTE (Edser @ Oct 16, 2012 - 7:12 P...   Oct 17, 2012 - 12:20 AM
- - Syaoran   Ok, so as far as an update. Car is down because t...   Oct 23, 2012 - 1:45 AM
- - Smaay   i have a complete 3S-GTE head if you want to go th...   Oct 23, 2012 - 8:34 AM
- - Syaoran   I was considering that possibility. What gen is it...   Oct 23, 2012 - 8:56 AM
- - Syaoran   Teins arrived, changed the oil filter to OE Toyota...   Oct 26, 2012 - 12:28 AM
- - Syaoran   Update: From top->bottom and left->right ...   Nov 5, 2012 - 6:54 PM
- - Syaoran   So..... I'm scheduled to drop the car on Satur...   Nov 11, 2012 - 2:09 AM
- - Syaoran   Took out the marshmallows!   Nov 16, 2012 - 8:32 PM
- - Syaoran   The Celi is under the scalpel!   Nov 17, 2012 - 10:42 PM
- - Fuzzyfo   Your car is coming together real well mi hermano, ...   Nov 17, 2012 - 10:57 PM
- - Syaoran   Can't wait until I have it back... bodywork gu...   Nov 18, 2012 - 12:46 AM
- - Syaoran   Progress Pics:   Nov 19, 2012 - 3:27 PM
- - Syaoran   More pics! Roof getting fixed... had to use g...   Nov 21, 2012 - 3:05 PM
- - Edser   Gosh! I love when you can see how smooth and s...   Nov 21, 2012 - 3:38 PM
- - Syaoran   Yeah my guy did a pretty good job. I can't wai...   Nov 21, 2012 - 9:10 PM
- - Syaoran   Couple coats of clear, prior to buffing:   Nov 23, 2012 - 1:43 AM
- - Edser   OH YEAH! Looking good!   Nov 23, 2012 - 4:28 AM
- - Syaoran   Thanks! I hate me and my obsession with wheel...   Nov 24, 2012 - 1:39 AM
- - Syaoran   It's done!   Nov 25, 2012 - 12:14 AM
- - JasonX   You did a great job man. Looks great.   Nov 25, 2012 - 12:23 AM
- - Syaoran   I don't like taking credit for work I didn...   Nov 25, 2012 - 12:55 AM
- - JasonX   This will definately will be a thread I will enjoy...   Nov 25, 2012 - 3:50 AM
- - richee3   The paint looks great.   Nov 25, 2012 - 10:09 AM
- - Syaoran   QUOTE (JasonX @ Nov 25, 2012 - 4:50 ...   Nov 25, 2012 - 12:03 PM
- - Syaoran   So a small update: I finally mounted the Tein spri...   Nov 28, 2012 - 3:02 AM
- - Syaoran   Small preview: Still no wheels on.   Nov 28, 2012 - 3:45 PM
- - Syaoran   Instagram'd pic (I need a real camera): And...   Nov 28, 2012 - 4:25 PM
- - rave2n   Looking good! Love the paint.   Jan 7, 2013 - 11:38 AM
- - Syaoran   Thanks!   Jan 7, 2013 - 12:12 PM
- - mindone   Nice restoration job! Look forward to seeing i...   Jan 8, 2013 - 8:06 PM
- - Syaoran   I want to see it soon with the wheels too haha...   Jan 8, 2013 - 8:30 PM
- - jordisonjr   Won't those new wheels be really sunk in?   Jan 9, 2013 - 5:23 PM
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: August 26th, 2026 - 3:16 AM
