May 20, 2012 - 3:34 AM
>>LET'S GO OVER REAL QUICK OUR REPLACEMENT OPTIONS OUT THERE:
TOYOTA OEM FRONT ENDLINKS Item #4: $61.50 ![]() TOYOTA OEM REAR ENDLINKS Item #4: $45.75 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() SWAY BAR LINK INSPECTION: Condition.............Code........Procedure Attaching hardware incorrect .............. A .......... Require replacement of incorrect part, if available; otherwise, replace link. Attaching hardware loose .................. A ... Require repair or replacement of loose part, if available; otherwise, replace link. Attaching hardware missing ................ C .. Require replacement of missing part, if available; otherwise, replace link. Attaching hardware threads damaged ........ A ... Require repair or replacement of part with damaged threads, if available; otherwise, replace link. Attaching hardware threads stripped (threads missing) ...... A ..... Require replacement of part with stripped threads, if available; otherwise, replace link. Ball and socket has looseness (perceptible vertical movement) ..... 1 ........ (1) Suggest replacement. Ball and socket has looseness that is excessive .............. B ..... (1)(2) Require replacement. Bent .................... B ............ Require replacement. Broken .................. A ............ Require replacement. Corroded, affecting structural integrity ... A ............ Require replacement. Grease boot cracked ..... 2 ........ (3) Suggest replacement. Grease boot missing ..... 2 ........ (4) Suggest replacement. Grease boot torn ........ 2 ........ (5) Suggest replacement. Missing ................. C ............ Require replacement. Nut on stud loose ....... A ............. (6) Require repair. Stud bent ............... B ........ (7) Require replacement. Stud broken ............. A ........ (7) Require replacement. Threads damaged ......... A .. Require repair or replacement. Threads stripped (threads missing) ............... A ........ (7) Require replacement. (1) - If manufacturer’s procedures for inspection exist, use those procedures; otherwise, use an approved inspection method such as the dry park check. CAUTION: DO NOT use pliers or pry bar to check ball and socket movement. Use only moderate hand pressure. (2) - Excessive looseness is defined as being significant enough to affect vehicle handling or structural integrity. (3) - Cracked grease boot will allow contaminants to enter the joint and will accelerate wear. (4) - Lack of grease boot will allow contaminants to enter the joint and will accelerate wear. (5) - Torn grease boot will allow contaminants to enter the joint and will accelerate wear. (6) - Check for bent stud or damaged taper hole. (7) - Check for damaged taper hole. TOOLS NEEDED TO REMOVE AND REPLACE ENDLINKS: ![]() Real Quick On Removing and Installing Endlinks: 1. Jack up the car in the correct jacking points, place jack stands in correct jack stand areas. Refer to manual or on this forum. I guess to be safe you can block the wheels depending if you are doing front or back. 2. Take off wheel. 3. Identify the endlink to be replaced. 4. Use 14mm wrench to remove nut, must be used with allen wrench at the same time so that nut does not move with the stud. Repeat for the other nut. (If yours is stuck use vise grips on the other side of the sway bar so you can lock it in place. Refer here: http://www.6gc.net/forums/index.php?showtopic=41243. You can also use a disc grinder but be careful. 5. Once both nuts are removed you can take off the endlink. Sometimes you have to use like scissor jacks to play with the knuckle and lift it up and down if the endlink is stuck - same thing goes for removal and installation. NOTES: However some aftermarket endlinks do not have the part where the allen wrench goes in to hold the stud from moving. I suggest depends on the endlink you can slip a wrench on the other end's inner nut or you can install the outer nut onto the endlink first meaning not on the car. Note: Some aftermarket endlinks use bigger nuts than OEM like 15mm or so. Some aftermarket links like MEVOTECH or MOOG, if you put on the nut almost halfway but then it gets tight after that and it makes the stud spin, so before installing onto the car, use two wrenches and install the nuts onto the links first (not on the car) and then remove, then install onto the car - this will make the threads ready for the nut to go on easier. If your endlinks still have the center part where an allen wrench can fit into then no worries, removal and install is simple. In simple terms you gotta get out the endlink and put on the endlink, depending how they come off and on. GREASABLE ENDLINKS (Sometimes Only offered for certain cars, by certain brands, or if there is a common problem with a specific car model): In my case I also used a grease gun on the fittings cus mine came with them. For the MOOGs it was not necessary to add more grease, they looked pretty full but the MEVOTECH's looked less so i used the grease gun on these links. Technically you can tell when to stop pumping grease when it begins to slightly ooze out of the boot. It might ooze out more once you lower the car. In most cases, if your car is on the ground, and if you can fit under there, this is the right time to put grease cus its already settled into its final suspension load. Its pretty straight forward, but I don't want to get too detailed unless you guys want me to elaborate. 6. Pretty simple - installation is reverse. Pls see below torque spec. ![]() Introduction and Options: What are Endlinks? In general, end links are also known as sway bar links. These are the parts that connect your sway bar to the lower control arm, which induces twist into the sway bar as it moves up and down, thereby reducing body roll. End links are bolted to a round opening at either end of the sway bar, and then into round openings in the lower control arm, knuckle, and/or Strut. The sway bar is also connected to the car’s frame by way of sway bar mounting or frame bushing. Worn out end link bushing can allow your car’s body to roll while cornering. Now, I just wanted to give you guys somewhat of an informed update on me upgrading to the MEVOTECH front sway bar endlinks and MOOG rear sway bar endlinks. My links are bad so I am just trying to get something better than OEM. I'm not trying to loose much of the OEM drivability. I'm sure higher end products change the feel of the car especially if you combine them with sway bar bushings and sway bars and make it more for sporty driving or track. My Other Options:#1. I could have gotten the GT4 Racing PolyUrethane endlinks that come with Polybushings (non-adjustable) that i'm sure would be good for track and stiff feel but was not sure how this would affect ride quality so opted for upgraded OEM replacement links that are beefier but still use the ball joint design. There is also lots of talk about how the possibility over time the poly bushings material in general tend to squeak and I did not want to deal with that idea, I could be wrong or whatsoever, and I don't know anyone that has GT4 Racing ones that could vouch for it specifically for our cars. The product is semi-brand new if not brand new since no one has it yet. http://www.gt4-racing.eu/index.php #2. There are other options that azian_advanced found for the rears only which are adjustable hex poly bushing endlinks which may be an option for you. There are also the TwosRUs adjustable endlinks for front and rear and comes in red/stainless finishes and full stainless finish which costs alot more. You can read on both here on http://www.6gc.net/forums/index.php?showto...&hl=twosrus Actual Install and Results: Good thing about both MEVOTECH and MOOG besides they are obviously beefier are that they are both greasable and come with Zerk Fittings (this I hope makes the links last much longer). But with the beefiness and zirk fittings, makes it to me more of an upgrade from regular endlinks that have neither especially the going rate for OEM "toothpick" endlinks that cost about 50-70 bucks eachx4. For the MOOG brand, needs no introduction, they are respected in the suspension/chassis arena. In fact, I went ahead and bought me MOOG inner and outer tie rods to go along with it. Thinking of the lower ball joints to be MOOG too. To get started...Here are pics of the front stock endlinks still installed. Needs no explanation, looks weak, thin, and breaks fast. ![]() Here are pics of the comparison side by side for the front. As you can see the MEVOTECH front links are much beefier. As Spider once mentioned they are 13mm compared to the stock 8mm on the rod size. Comes with a nice blue boot cover but thats just for show. I read that the black boot covers are the newer designed ones (supposed to be better) which i've seen as well but dunno the difference of how some say its better. FYI, MEVOTECH for some reason offers their beefier models for both front and rear for our model. For other cars, MEVOTECH sometimes provide the stock skinny ones for example for the 7gc. I guess we are lucky. The reason why i decided on getting MEVOTECH for the fronts and not MOOG all around is because MOOG front links seem to be like stockish looking and its size - I did not know for sure but i've seen the fronts for other cars and they size up the same as stocks. ![]() Here are pics of the MEVOTECH Front endlinks installed. Nice! ![]() Here are the pics of the rear stock endlinks still installed. Again, scrawny. ![]() Here are the side by side pic comparison for the rear. As you can see the MOOGs are definitely beefier. Comes with a nice MOOG black boot cover with their logo. Also has the greasable zerk fittings. I did not opt to match MEVOTECHs in the rear only because I know MOOG is top-notch replacements. Again MOOG rear endlinks are much better in design than their front version, thus the mix and match with MEVOTECH's fronts. MOOG fronts just look like stock (which I'm sure is just equal or a bit better than OEM). MOOG I believe may offer this same design for the fronts and rears but not for every car, in our Celica's case, just the rears are the nicer ones. ![]() Here are pics of the rear MOOG endlinks installed. Sorry crappy phone night pics. But Definitely looks beefier and nicer. ![]() Review and feedback of the ride upgrade. Car feels much stiffer, very noticeable, there were turns I used to take with my worn out ones and I would just feel the car tilt, now its more stable with these ones. Turn-in is great, im hugging turns a lot better now. Definitely a good feeling. I thought maybe there wouldn't be a difference but there is. I will probably loose that feeling over time when i get used to it, but as of now its a night and day difference. In conclusion, there are many decent OE replacements out there, Autoextra, MEVOTECH, DEEZA, Beck and Arnley, AC Delco, Raybestos (Service and Professional Grades), NAPA, whitelines (AUS), MOOG, etc. - some better than others. MOOG and RAYBESTOS (Pro Grade) are good choices for ball joint types. I'm not trying to promote the products I installed, just wanted to tell you my experience on this setup. Again there are many brands out there, mix and match parts, etc. for you to choose from. Another good tip is that there are some cars that share the same endlinks either front/rear interchangeable so that means if other cars have a performance version thats an option for you too. A good example was azian_advanced's Miata rear endlink find. Also with adjustable endlinks since they are hex types, you can flip the bolt/stud to face in same or opposite directions and adjust height length as well giving you more options < as so i think i understand it that way. For the most part what endlinks are its generally the same its really just a matter of length and the direction of the studs for it to fit. So good luck on your endlink jobs and be safe when doing it. Again constructive feedback is welcome so that we can make it better if anything... ENDLINK WRITE-UP BY:
This post has been edited by trdproven: May 29, 2012 - 11:06 PM -------------------- 94 Celica GT
trdproven ENDLINK INFORMATIVE - QUICK HOW-TO ENDLINKS May 20, 2012 - 3:34 AM
SwissFerdi Great guide. May 20, 2012 - 7:09 AM
azian_advanced just to add, if worst comes to worst and you still... May 20, 2012 - 9:17 AM
trdproven QUOTE (azian_advanced @ May 21, 2012 - 1... May 20, 2012 - 3:33 PM
benzo how much did they run you?>
nice guide tho... May 20, 2012 - 11:36 AM
jordisonjr Sticky for sure.
There's been a ton of talk on... May 20, 2012 - 1:29 PM
Spider77 Well, Im glad your enjoying your new endlinks. Iv... May 20, 2012 - 2:19 PM
trdproven QUOTE (SwissFerdi @ May 20, 2012 - 10... May 20, 2012 - 8:15 PM
BonzaiCelica great thanks!! liking what I'm seeing.... May 21, 2012 - 12:33 AM
trdproven Sorry I'm lost removing what little pin? are ... May 21, 2012 - 2:14 AM
BonzaiCelica QUOTE (trdproven @ May 21, 2012 - 2... May 21, 2012 - 8:14 PM
marinos What is your opinion about the gt4 racing has anyo... May 21, 2012 - 5:23 AM
trdproven im not sure...but poly material has been known to ... May 21, 2012 - 3:39 PM
trdproven Well, old in terms of not newer than the new greas... May 21, 2012 - 8:19 PM
Stambo great guide, i guess i'm spoiled though by bei... May 21, 2012 - 8:54 PM
BonzaiCelica hey the guys with st sway bars. I always have a ha... Jun 27, 2012 - 2:14 AM
trdproven i just jack it up from the bottom. The trick with... Jun 27, 2012 - 2:29 AM
Syaoran Great write-up and it's nice to see a first-ha... Jun 27, 2012 - 2:05 PM
BonzaiCelica makes sense trdproven. I'll have to remove bot... Jun 27, 2012 - 10:17 PM
BonzaiCelica well I ordered mine from rock auto for $45 sh... Jul 4, 2012 - 2:06 PM
Syaoran QUOTE (BonzaiCelica @ Jul 4, 2012 - 3... Jul 5, 2012 - 6:29 PM
trdproven wow, i was wondering on the internet why there wer... Jul 4, 2012 - 5:29 PM
trdproven MEVOTECH seem to be following MOOG designs more an... Jul 5, 2012 - 11:04 PM
BonzaiCelica yea that's what I was going to mention. it sho... Jul 6, 2012 - 1:54 AM
trdproven the problem with those covers is that i assume the... Jul 6, 2012 - 6:24 PM
trdproven late post, but it sounds like you could always pee... Aug 26, 2012 - 10:27 PM
BonzaiCelica QUOTE (Spider77 @ Mar 6, 2012 - 1:55... Nov 6, 2012 - 12:53 AM
BonzaiCelica update: So i fitted the mevotech rear end links, b... Jan 3, 2013 - 3:45 PM
Spider77 I didnt really notice anything on mine....but ill ... Jan 3, 2013 - 7:31 PM
BonzaiCelica QUOTE (Spider77 @ Jan 3, 2013 - 8:31... Jan 3, 2013 - 7:44 PM
Spider77 I'll have to keep that in mind...Im sure somew... Jan 3, 2013 - 8:03 PM
BonzaiCelica QUOTE (Spider77 @ Jan 3, 2013 - 8:03... Jan 3, 2013 - 9:00 PM
trdproven bonzai do you have an oem strut to compare to. it... Jan 7, 2013 - 9:28 AM
Syaoran Perhaps might be a better idea to get a set of mia... Jan 7, 2013 - 11:57 AM
BonzaiCelica From: rrego@mevotech.com
To: bonzaicelica@hotmail.... Jan 7, 2013 - 5:45 PM
trdproven QUOTE (Syaoran @ Jan 8, 2013 - 2:57 ... Jan 7, 2013 - 11:28 PM
BonzaiCelica i'll get a pic of the stock end links on.
ha ... Jan 8, 2013 - 12:52 AM
trdproven i can try when i get the chance, for the most part... Jan 9, 2013 - 5:24 PM
BonzaiCelica THIS IS WITH THE CAR ON THE GROUND ON ALL 4 TIRES... Jan 11, 2013 - 6:43 PM
MaskedMan Here is a comparison of the stock rear sway bar to... Jan 13, 2013 - 2:24 PM
BonzaiCelica what gives. see they are exactly the same.
the m... Jan 13, 2013 - 3:14 PM
Spider77 I'll get you pics up tomorrow. With some meas... Jan 13, 2013 - 9:21 PM
Rusty they may look the same length, but are the holes i... Jan 14, 2013 - 2:47 AM
Spider77 Alright, so I went out and took some measurements ... Jan 14, 2013 - 2:54 PM
SwissFerdi I wouldn't worry about wear on the links, I... Jan 14, 2013 - 4:47 PM
Spider77 For me everything is fine...no problems so far. Jan 14, 2013 - 5:33 PM
trdproven I took pics of my MOOG endlinks (the thick ones li... Jan 16, 2013 - 7:31 PM
BonzaiCelica we want pics post it up!!! Jan 16, 2013 - 9:04 PM
trdproven as you can see or barely see cus these are not pic... Jan 23, 2013 - 8:18 PM
BonzaiCelica i do have a caliper at my dads place but he's ... Jan 24, 2013 - 2:00 AM
trdproven i dont have the stock links anymore just a spare m... Jan 24, 2013 - 6:49 AM
BonzaiCelica well to put to death the sizing info
as you ca... Jan 24, 2013 - 6:22 PM
trdproven i see, yup thats why i provided the length of my M... Jan 24, 2013 - 6:33 PM
BonzaiCelica they might be like 5mm longer, but thats really no... Jan 24, 2013 - 7:47 PM
BonzaiCelica alright people problem solved! Jan 25, 2013 - 3:41 AM
Spider77 This is what I got back from MevoTech
"Please... Jan 25, 2013 - 5:40 PM
BonzaiCelica yes dude that is the problem. masked man let me kn... Jan 25, 2013 - 6:44 PM
azian_advanced Spider77, do you have pics of the endlinks while t... Jan 25, 2013 - 10:30 PM
trdproven QUOTE (azian_advanced @ Jan 26, 2013 - 1... Jan 28, 2013 - 5:12 AM
BonzaiCelica QUOTE (Spider77 @ Jan 14, 2013 - 3:5... Jan 26, 2013 - 3:14 AM
BonzaiCelica MEVOTECH
now as you can see people masked man was... Feb 8, 2013 - 2:17 AM
trdproven yea thats what i was saying about lining up one of... Feb 8, 2013 - 3:55 AM
BonzaiCelica oh yes i will bend bracket once i get a big enough... Feb 8, 2013 - 4:22 AM
trdproven QUOTE (BonzaiCelica @ Feb 8, 2013 - 7... Feb 8, 2013 - 5:37 PM
mkernz22 I'll have to get some pictures next weekend si... Feb 8, 2013 - 12:02 PM
BonzaiCelica as you can see even the original housing is basica... Feb 8, 2013 - 1:59 PM
trdproven too bad my teins are for my 7th gen. Feb 8, 2013 - 5:32 PM
richee3 Here are my RacingBeat Miata end links with stock ... Feb 19, 2013 - 12:55 PM
trdproven i get it already, my pics were blurry, but its not... Feb 24, 2013 - 5:20 PM
BonzaiCelica thx to diego i got the pic muhaha see fits perfect... Apr 17, 2013 - 2:19 PM
mi645 Hello I read on twos r us that twos r us end links... Apr 18, 2013 - 7:05 AM
BonzaiCelica Edit why did i even waste my time Apr 18, 2013 - 2:29 PM
mi645 I already have sw20 stainless end links for my sw2... Apr 19, 2013 - 2:36 AM
malecrod Just wanna add. I tried the mevotech end links fr... Apr 21, 2013 - 10:41 AM
BonzaiCelica QUOTE (malecrod @ Apr 21, 2013 - 10... Apr 21, 2013 - 1:02 PM
BonzaiCelica Moog rear End links. oh yes i took one left hander... Jun 3, 2013 - 1:34 PM
trdproven wow haven't been here for a bit so you did the... Jun 5, 2013 - 10:47 AM
yellowchinaman Mine.
To me I don't get the logic of a movin... Jun 13, 2014 - 6:19 AM
toyota123 That's a hefty part there. Interested in how y... Jun 13, 2014 - 7:08 AM
yellowchinaman QUOTE (toyota123 @ Jun 13, 2014 - 8... Jun 13, 2014 - 1:49 PM
Batman722 Stiffer links like those make a noticeable improve... Jun 13, 2014 - 2:41 PM
yellowchinaman Had a blast around some bends just now and WOW... Jun 13, 2014 - 5:31 PM
jordisonjr Did you make those links?
They look really solid. ... Jun 14, 2014 - 12:14 AM
yellowchinaman QUOTE (jordisonjr @ Jun 14, 2014 - 1... Jun 15, 2014 - 3:16 PM
955SFE For the Miata Racing Beat does it matter if I get ... Sep 1, 2014 - 1:53 PM
richee3 They are the same. I know it's difficult to re... Sep 1, 2014 - 2:26 PM
955SFE I can see it.
Did you get around in installing the... Sep 1, 2014 - 3:57 PM
richee3 I've had them in for a year and a half, maybe ... Sep 1, 2014 - 5:34 PM
njccmd2002 well ordered my racing beats too today... Nov 5, 2014 - 10:08 PM
njccmd2002 im tempted to install them on the front.. Nov 13, 2014 - 3:45 PM
Batman722 I always wanted to do that.
You need a nut in bet... Nov 13, 2014 - 6:12 PM
njccmd2002 that was a test fit, with something i hacked in 5 ... Nov 13, 2014 - 7:27 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 11:35 PM |
