May 20, 2012 - 4:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
So my ECT sensor went bad and I replaced it. This was when I noticed it kept over heating randomly but then suddenly goin back down to cool again. I tried bleeding it but it didn't work. I think I might just be bleeding it wrong?
How I bled it was drove my car up to my drive way(up hill slope). Opened the radiatior cap. Turned the car on and blasted the heater. I poured coolant into the radiator and kept it overflowing so all the airpockets can get out. I did that for like 10 min. Its a lil netter but I think ima have to bleed it again? -------------------- |
May 20, 2012 - 5:50 PM
You burped the coolant system properly. However, that sounds like a thermostat issue to me. It seems as if the thermostat is beginning to fail and is opening too late.
May 20, 2012 - 6:12 PM
when you bled the air, did both hoses get fully hot?
May 21, 2012 - 3:41 AM
You burped the coolant system properly. However, that sounds like a thermostat issue to me. It seems as if the thermostat is beginning to fail and is opening too late. Sorry about that. I forgot to mention that I also replace the Thermostat with a New 170 Thermostat. Do you know if our cars have a bleed valve at all? when you bled the air, did both hoses get fully hot? Yea. Both got hot. I just don't think I'm doing it properly. I'll have to redo it again and if it doesn't work then a different method. -------------------- |
May 30, 2012 - 3:50 PM
Enthusiast ![]() Joined Jul 20, '11 From Houston tx Currently Offline Reputation: 2 (100%) |
sounds like mines doin the same thing i cant seem to fix it. already replaced almost whole coolant system
May 30, 2012 - 4:31 PM
Enthusiast Joined May 12, '12 From Phoenix Currently Offline Reputation: 1 (100%) |
Is this the same issue as in this thread?
May 30, 2012 - 7:13 PM
yea its lookin like it
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:35 AM |
