May 20, 2012 - 8:49 PM
Enthusiast ![]() Joined Nov 23, '11 From Tampa, FL Currently Offline Reputation: 0 (0%) |
okay, so i have brand new rebuild kits, i purchased all these things to rebuild my girls Celica, so i have the following items up for grab still packaged sealed i will post pics later of the packages:
FULL GASKET SET: ***80 TO 100*** 1- Head Gkt. (Graphite) 1- Valve Cover Gkt. 1- Intake Manifold Gkt. 1- Exhaust Manifold Gkt. 16- Valve Stem Seals (Viton) 1- Cam Seal 4- Spark Plug Tube Seals 1- Exhaust Pipe Ring 1- Fuel Injector O Ring Set 1- AGR Gkt. 1- Water Outlet 1- Conversion Set (Lower Set) PISTON RINGS (NPR brand - Made in Japan) ***85 TO 120*** 4- Pistons with Pins Clips 1- Set of Piston Rings ENGINE BEARINGS *** 70 TO 90*** 1- Main Bearing Set 1- Rod Bearing Set 1- Thrust Washer Set Oil Pump *** 100 TO 160*** Timing Belt *** 30 TO 40*** 1- Timing Belt Freeze Plug Set *** 20 TO 30*** ***WOULD LIKE TO SELL AS A WHOLE BUT I AM WILLING TO PART OUT IF NEEDED*** I POSTED PRICES LOOKING TO GET, DNT BE AFRAID TO MAKE AN OFFER OTHER THAN LISTED WHATS THE WORST I CAN SAY.... NO. TEXT OR CALL, IF I DNT ANSWER LEAVE A MESSAGE ROB. 8139777084 This post has been edited by Rusty: May 20, 2012 - 10:46 PM
Reason for edit: please remember to add 'FS' in the topic title
May 21, 2012 - 11:38 PM
May 26, 2012 - 9:52 PM
seriously make me offee i need sell things.. really could use the extra cash.
Aug 22, 2014 - 9:24 PM
Enthusiast ![]() ![]() Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
are those oversized pistons? if so how much?
| Lo-Fi Version | Time is now: June 10th, 2026 - 10:38 AM |
