Nov 18, 2002 - 12:40 AM
![]() Enthusiast ![]() Joined Nov 17, '02 From Mission Viejo, CA Currently Offline Reputation: 0 (0%) |
Nov 18, 2002 - 12:46 AM
Enthusiast ![]() Joined Aug 31, '02 From Bay Village, OH Currently Offline Reputation: 0 (0%) |
Go to Celica.net and talk to either KUYA or DAZED128. Kuya may have all the parts you need for the swap, and Dazed has done it and knows everything about it.
¤Chrí§¤ |
Nov 18, 2002 - 12:56 AM
Thanx man. Any tips you can give me for first mods?
Nov 18, 2002 - 12:57 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
I had it done to my celi about 3 months ago.
Let me find Dazed's post about it. -Bryan- -------------------- Member of Team 5sfTe
QUOTE (Element23 @ Nov 17 2002, 10:56 PM) Thanx man. Any tips you can give me for first mods? The tranny would be a good one. -Bryan- -------------------- Member of Team 5sfTe
Nov 18, 2002 - 1:04 AM
Haha, so much feedback. You guys are amazing, didnt think i would get this great of a response within like 30 minutes!
Nov 18, 2002 - 1:12 AM
Here
Here (good one) Also this is a quote from the FAQ at c.net. (2) How much does it cost and what is involved in a tranny swap. For the unlucky people with an automatic transmission, a transmission swap is much easier than most people think. Most of the supplies (all except the clutch kit) can be purchased from junkyards, minimizing the cost. Using an OEM clutch (I would recommend getting a better one), the entire swap would cost around 1000, and his is probably a slight overestimate. Here is a quick part list breakdown...: Shift fork (If it does not come w/ the tranny) Clutch pedal Clutch Kit Bolts to hold Tranny to Engine Master Cylinder Slave Cylinder Hydrolic lines between Master and Slave Cylinder Manual Transmission New driver side engine/tranny mount Brake pedal (or you can dremel the current brake pedal to cut it down to the right size, this is what I did to save costs and then purchased the right rubber cover to go over it) **You do not not to get a Manual ECU, instead you just need to connect two wires to make it work w/ ur auto ECU. *** The hardest part of the process is cutting the hole for the master cylinder. The master cylinder has two bolts and a rod that goes through the firewall. There is a spot that is already imprinted on the fire wall to konw where to drill, but the imprint is slightly larger than what you actually need to drill out, so make a pattern to go by before drilling. then the master cylinder has a metal hose that goes to a rubber hose that goes to a metal hose that goes to yet another rubber hose that finally connects to the slave cylinder on the tranny. You have to support the engine and lower the old tranmission. put the clutch in the manual tranmission following the instructions provided by the manuafacturer, and then put in the new tranmission. you have to junp two wires (sorry forgot which two, but if u do a search u can find it) to get it to work with the automatic ecu. Then connect the slave and master clyinder and then you are pretty much golden. Obviously I kept most of the detail out to keep this FAQ as short as I could, so USE THE SEARCH, there have been lots of posts... here is some more info on the tranny swap Hope that helps. -Bryan- -------------------- Member of Team 5sfTe
Nov 18, 2002 - 2:27 PM
Yea. hopefully ill be able to do this swap. I want to swap the engine to the 3sge or 3sgte, but i cant seem to find em in california or the US. Is the 3sgte in england/europe only?? im sure the 3sge is here, but not the T...
Nov 18, 2002 - 4:16 PM
They have them at a lot of places, you just have to wait for the right one to come along.
| Lo-Fi Version | Time is now: May 18th, 2026 - 2:35 PM |
