Jun 1, 2012 - 11:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Lately, I've been noticing an odd, whistling noise when I accelerate. Only from a cold start and it's more prominent in the lower gears (I'm accelerating normally, I'm not hauling ass). It always seems to die down when I shift gears and it starts to pick back up when I continue to accelerate. Any ideas, guys?
June '12 COTM '95 AT200 |
Jun 1, 2012 - 12:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
... supercharger?
Jun 1, 2012 - 12:15 PM
In retrospect, I pretty much described a supercharger, huh?
This post has been edited by HectortheRican: Jun 1, 2012 - 12:15 PM -------------------- taking too long to mod since '09
Jun 1, 2012 - 12:16 PM
Hahaha - I couldn't resist.
Would you consider it a definite whistle? Or maybe a high pitched squeal? -------------------- |
Jun 1, 2012 - 12:46 PM
Not quite a squeal, like the squeal that the accessory belts make when they're cold/bad. Just more like a whistle that increases in frequency as the engine speeds up. The whistle goes away at higher gears and when the engine warms up.
Jun 1, 2012 - 12:50 PM
![]() Enthusiast ![]() Joined May 29, '12 From NC Currently Offline Reputation: 0 (0%) |
Do you have an aftermarket intake? they can whistle.
Have you messed with anything recently? could also be a vacuum leak. Anyway you could make a video so we could hear it exactly? -------------------- ![]() Cleaning and improving my new found yoter little by little. |
Jun 1, 2012 - 1:58 PM
Do you have an aftermarket intake? they can whistle. Have you messed with anything recently? could also be a vacuum leak. Anyway you could make a video so we could hear it exactly? It'll be difficult to record because it only happens when I'm moving. I've had my Injen SRI for almost 2 years and this is the first time, so I don't think it'd be that. Maybe there's a very small hole in the filter and that's what's making the whistling noise? I'll see what I can do about checking for vac leaks, though. -------------------- taking too long to mod since '09
Jun 1, 2012 - 2:12 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I have the same problem...stupid turbo...
On a more serious note: likely just the synchros/gears in your transmission winding up and down. Viscosity of the tranny fluid will change with heat. Perhaps its time to change your transmission fluid. -------------------- ![]() |
Jun 1, 2012 - 2:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
My buddy had this problem before too in one of his cars, although it was all the time.
Turned out to be a bearing of some sort. I believe in his ac. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 1, 2012 - 2:30 PM
I have the same problem...stupid turbo... On a more serious note: likely just the synchros/gears in your transmission winding up and down. Viscosity of the tranny fluid will change with heat. Perhaps its time to change your transmission fluid. Really? Because I changed it, not even 6 months ago. -------------------- taking too long to mod since '09
Jun 1, 2012 - 4:29 PM
Start noticing it shortly after the fluid exchange?
Jun 1, 2012 - 4:51 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
I have that samw sound since i redone my intake
Do you have all the extra little ports on your intake capped off an it could be your trans too mine does it but its only noticable in 1st an reverse -------------------- 95 gt coupe, v6 swap weekend toy
Jun 1, 2012 - 5:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
A/C compressor whine?? mine's been doing that lately, acts the same as you've described.
-------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Jun 1, 2012 - 5:47 PM
Start noticing it shortly after the fluid exchange? No, I changed the fluid in December and I noticed this whistle a few days ago. I have that samw sound since i redone my intake Do you have all the extra little ports on your intake capped off an it could be your trans too mine does it but its only noticable in 1st an reverse Yep, I've got every little hole capped off. A/C compressor whine?? mine's been doing that lately, acts the same as you've described. I don't have the AC on when I hear the whistle. -------------------- taking too long to mod since '09
Jun 2, 2012 - 11:07 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
I have the same thing lately. But only under wide open throttle and at revs above 3800. I could never figure it out, but an ac bearing sounds like it might be the cause. So I'm gonna check it out soon
Jun 5, 2012 - 5:51 PM
On idle, try pushing in your clutch pedal. I assume the sound disappeared when you accelerated cus you pressed in the clutch for that moment. if the sound disappears its your Throw Out Bearing on your Tranny.
Jun 5, 2012 - 6:10 PM
On idle, try pushing in your clutch pedal. I assume the sound disappeared when you accelerated cus you pressed in the clutch for that moment. if the sound disappears its your Throw Out Bearing on your Tranny. I'll give that a try. Sometimes I hear it at idle and sometimes I don't. I've been needing to flush my PS fluid, which I will do as soon as I get time this week. Do you think bad PS fluid could cause a bearing in the PS pulley to get squeaky/whistle-y? -------------------- taking too long to mod since '09
Jun 5, 2012 - 8:10 PM
if your p/s pump was bad, you'd hear it all the time even parked but if anything more louder when you turn. if it were the pulleys or bearings are a little bit more distinguishable and since those pulleys move all the time as long as the motors running you would be able to tell easily cus you could just stand in front of the car and listen to it. in your case, you described it basically everytime you pressed the clutch when you shifted and cold start.
the only thing else i could tell you is maybe you have a bad ground wire for sounds, cus that follows acceleration also. did you work on anything electrical? This post has been edited by trdproven: Jun 5, 2012 - 8:14 PM -------------------- 94 Celica GT
Jun 5, 2012 - 8:37 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
I use to hear it from a small crack in my rubber intake piping
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jun 5, 2012 - 10:35 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) |
I used to have a similar problem on my old 7A... though I think it was from this long crack along my exhaust manifold (at least that was the only thing I could contribute it to... could have been intake, never thought of that... its easy enough to check the exhaust manifold though.
Kevin |
| Lo-Fi Version | Time is now: August 25th, 2026 - 2:01 AM |
