Jun 1, 2012 - 11:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Lately, I've been noticing an odd, whistling noise when I accelerate. Only from a cold start and it's more prominent in the lower gears (I'm accelerating normally, I'm not hauling ass). It always seems to die down when I shift gears and it starts to pick back up when I continue to accelerate. Any ideas, guys?
June '12 COTM '95 AT200 |
HectortheRican Whistling noise at acceleration? Jun 1, 2012 - 11:58 AM
KAOS ... supercharger? Jun 1, 2012 - 12:00 PM
HectortheRican In retrospect, I pretty much described a superchar... Jun 1, 2012 - 12:15 PM
KAOS Hahaha - I couldn't resist.
Would you consid... Jun 1, 2012 - 12:16 PM
HectortheRican Not quite a squeal, like the squeal that the acces... Jun 1, 2012 - 12:46 PM
Takumi-FujiWaraST Do you have an aftermarket intake? they can whistl... Jun 1, 2012 - 12:50 PM
HectortheRican QUOTE (Takumi-FujiWaraST @ Jun 1, 2012 ... Jun 1, 2012 - 1:58 PM
bsamps4 I have the same problem...stupid turbo...
On a mo... Jun 1, 2012 - 2:12 PM
HectortheRican QUOTE (bsamps4 @ Jun 1, 2012 - 2:12 ... Jun 1, 2012 - 2:30 PM
jordisonjr My buddy had this problem before too in one of his... Jun 1, 2012 - 2:15 PM
bsamps4 Start noticing it shortly after the fluid exchange... Jun 1, 2012 - 4:29 PM
kurt95gt I have that samw sound since i redone my intake
D... Jun 1, 2012 - 4:51 PM
smkr3w A/C compressor whine?? mine's been doing that ... Jun 1, 2012 - 5:24 PM
HectortheRican QUOTE (bsamps4 @ Jun 1, 2012 - 4:29 ... Jun 1, 2012 - 5:47 PM
enderswift I have the same thing lately. But only under wide ... Jun 2, 2012 - 11:07 PM
trdproven On idle, try pushing in your clutch pedal. I assu... Jun 5, 2012 - 5:51 PM
HectortheRican QUOTE (trdproven @ Jun 5, 2012 - 5:5... Jun 5, 2012 - 6:10 PM
trdproven if your p/s pump was bad, you'd hear it all th... Jun 5, 2012 - 8:10 PM
cjh4l22 I use to hear it from a small crack in my rubber i... Jun 5, 2012 - 8:37 PM
Soulend I used to have a similar problem on my old 7A... t... Jun 5, 2012 - 10:35 PM
HectortheRican QUOTE (trdproven @ Jun 5, 2012 - 8:1... Jun 5, 2012 - 10:59 PM
elizaharry It sounds like you have either a bad tire causing ... Jan 22, 2014 - 11:06 PM
Beezy_BoJanglez I have the same problem but I didn't always ha... Jul 14, 2014 - 1:04 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 12:49 AM |
