> Drilling though an intercooler, is it ok......?
post Jun 7, 2012 - 7:49 PM
DZracer978
Joined Mar 13, '06
hi guys,
I have bought a intercooler that doesn't have amounting bracket or a place to mount, I will need to put a couples of hole it. Is it ok or will damage the cooling system? I need some input before i start drilling? Thanks
post Jun 7, 2012 - 7:58 PM
bsamps4
Joined May 16, '10
From Raleigh
Dont drill. Take it to have bungs welded on it for mounting. You would likely have some trouble removing the metal shavings from inside the intercooler if you drilled it. Not the sort of bit that you would want to put under the scalpel.
post Jun 10, 2012 - 1:09 PM
All you have to do to mount an intercooler is make make a single 6inch long plate (about that length) and drill a hole through it for a 10mm bolt. Then just bolt it to the bottom center of the frame where your under body plastics normally bolt on to, so that it provides a place for the intercooler to rest. Thats it. The front bumper and the intercooler piping will hold it from moving around.
post Jun 10, 2012 - 5:29 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
+1 for welded bungs
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 2nd, 2026 - 1:15 PM
