Jun 12, 2012 - 8:51 PM
Enthusiast Joined Jun 12, '12 From virginia Currently Offline Reputation: 0 (0%) |
the car started making aclicking sound when i started it so i immediatly thought the starter was going bad. I checked the plugs and wires as well...both good. i pulled the starter and had it checked voltage is good, but the teeth on the gear is a little worn. the flywheel is worn a bit too. I dont know if i need to change both the starter and flywheel...or if anyone has any suggestions that would be great.
ps this is what the computer at advance said...1 flywheel tooth damage or wear. 2 tooth engagement depth/shimming. |
Jun 13, 2012 - 9:41 AM
i would replace both at this point. if you replace the flywheel and not the starter, the worn teeth will damage the new flywheel teeth. what engine is this? if its a 5S-FE, i suggest a new clutch and fidanza flywheel. the car responds much better with the lighter flywheel
Jun 13, 2012 - 11:03 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
^Agreed. The most of it is probably your starter. It sounds like the actuator is bad on it and has been going, most likely why teeth are bad. If you don't replace your flywheel now, you will regret it down the road. May be a month, may be a year. I wouldn't go too much lighter on the flywheel unless you plan on turboing it. The lighter the flywheel, the faster you'll rev, but the more mid and top end you lose. I had an 11lbs I think on my last Integra and I had a good loss in power past 100 mph, and a big loss past 130mph ... I couldn't get it past 145mph ... not that you need to go that fast, but this was also a built engine, you'll notice it well before 100 mph.
This post has been edited by Xander_X: Jun 13, 2012 - 11:06 AM -------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:24 AM |
