Jun 14, 2012 - 6:10 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
First of all, I'm assembling this engine with parts from people all over the forums since I have an engine that someone attempted to part out. With that said, I have two coolant necks that both fit the head but are different from each other. The coolant neck that I have used looks more like the one in the drawn picture below, but there is no nipple where I have drawn the "number 2", there is only a large threaded hole that I have a sensor in for my Autronic ecu.
I pulled the picture below from the handy manual that is posted in the stickies, I drew on it a little to allow my questions to be easier. The picture is not clear as to where "number 1" is going unless it goes into the coolant neck(most likely), and also I should mentioned that my "number 2" hose cannot connect to the coolant neck bolted into the side of the head because there is the threaded hole there. Basically, do I have the right coolant neck installed? I'm thinking that it is for a non-turbo 3s since it doesn't have the turbo water inlet on it, and what is the other one from? And is "number 1" running into the coolant neck like I think it is? ![]() this is the extra coolant neck that I have that looks different from the drawn picture above but still fits the head. What is it from? ![]() and this is the best picture I have right now of my other coolant neck that is close to the drawing above.
-------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
match220 gen III 3s coolant tube routing? Jun 14, 2012 - 6:10 AM
Sunny Hi,
nr.1 is the throttle body heat/idle water lin... Jun 14, 2012 - 2:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:18 AM |
