Jun 14, 2012 - 10:08 AM
Enthusiast ![]() Joined Aug 5, '10 From WOODHAVEN NY Currently Offline Reputation: 0 (0%) |
I have a set of headers on my Celica 7A-FE but I keep getting a leak right by my header gasket so I was looking into getting locking header bolts so I can tighten it up cleanly and avoid the head aches(police). Any help would be appreciated even the size bolt would help. Thanks
Jun 14, 2012 - 7:03 PM
the bolt is loosening or the flange is warped?
Jun 14, 2012 - 9:33 PM
Enthusiast ![]() Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
the bolt is loosening or the flange is warped? ^this. Take a file to your flange and make sure its flat. Learned this after working on aircooled flanges (hot,warpy). -------------------- |
Jun 15, 2012 - 9:15 AM
Headers? you have more than one in there? just busting your balls, he he. the bolts should be 10X1.25 get some studs from the dealer and new nuts they will hold
Jun 15, 2012 - 9:57 AM
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
Adding to Smaay's answer and taking it way farther than it needs to go.
If for some reason new nuts don't work, try loctite. If for some reason that doesn't work, and then try security locknuts. Now if this still isn't working, then nothing is going to hold it on and I don't even think that welding it directly to the head would work. In which case, you may need to start looking elsewhere for your problem(motor mounts or severe imbalance in the engine). -------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Jun 15, 2012 - 9:11 PM
loctite won't work on exhaust, it'll melt right off. You could use locking 'pinch' nuts though.
Jun 16, 2012 - 3:02 AM
loctite won't work on exhaust, it'll melt right off. You could use locking 'pinch' nuts though. I wasn't thinking about the heat. But realistically, there's no reason that just new studs and nuts wouldn't work. If they don't I'd start looking to see what could be causing them to come loose.-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Jun 25, 2012 - 2:13 PM
Thank you all great info I will look into this problem further you have all been great, much appreciated.
Jun 25, 2012 - 2:53 PM
its possible that the threads in the head are shot, then you will need to helicoil them
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:49 PM |
