> Engine identification
post Jun 15, 2012 - 1:28 PM
mrgignac
Joined May 18, '09
From Maine
Having some trouble identifying the engine in my 96 ST. The car ran perfectly until a friend of mine changed the plugs, now runs terrible. I then remembered When i purchased the car, the owner had said the engine was swapped out. i looked around the entire engine until finding a small tab under the alternator that read:
2T1BB02E2
TC167804
Ive googled it a bunch a times and looked for toyota engine codes but didnt see anything like it. any help would be appreciated.
post Jun 15, 2012 - 1:43 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
does the intake manifold say anything on top of it? if not its probly a 7afe as opposed to a 5sfe.
post Jun 15, 2012 - 1:48 PM
jimmykay
Joined Jul 14, '08
From St. Louis
both with short rams, but you get the idea.
5s-fe
7a-fe
'99 Celica GT - Sold
'11 Mazdaspeed3
post Jun 15, 2012 - 3:45 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Take a few pictures of the engine and post them here. We should be able to identify it
post Jun 15, 2012 - 3:57 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Yes a picture would be the easiest way of identifying what engine you have.
Are you sure your friend got the plug order correct, this is why me and me only works on my cars with the occasional extra set of hands when necessary.
Cleaning and improving my new found yoter little by little.
post Jun 15, 2012 - 4:21 PM
mrgignac
Joined May 18, '09
From Maine
heres a pic, and we checked to make sure the plugs were on the corresponding number on the distributor. im thinking the guy at the store looked up plugs for a 96 celica and i heard this engine might have been from a toyota wagon.
i appreciate all of the help guys, im so bad with cars
post Jun 15, 2012 - 4:33 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (mrgignac @ Jun 15, 2012 - 5:21 PM) *
Thats a 7A-FE engine. So at the store you'd be looking under Celica ST 1.8L. Not sure if the years matter.
This post has been edited by smkr3w: Jun 15, 2012 - 4:35 PM
post Jun 15, 2012 - 4:45 PM
mrgignac
Joined May 18, '09
From Maine
smkr3w, so i must have the right plugs cuz that's what they looked up for me and the plugs come gapped, has got to be wires or distrib then? thnx for your expertise
Everything on this car is so old, i wouldn't be surprised if we busted something while changing the plugs. i had bought a set of the 1.8 wires but still had the same problem so i returned em not knowing if i had the right engine.
post Jun 15, 2012 - 5:49 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
What exactly is it doing? Check engine ligt on?
What plugs are you running? NGK is always good and what most japanese cars call for. I would check the gap on the plugs anyway as just a slight bump/tap can mess with the gaping.
This post has been edited by Takumi-FujiWaraST: Jun 15, 2012 - 5:52 PM
post Jun 15, 2012 - 7:55 PM
mrgignac
Joined May 18, '09
From Maine
there were nkg's in it, but they were old and blackened. i got bosch platinums and now i dont know if a cylinder isnt firing or a wire is busted. it runs really rough. ive never had a problem with the engine in this car until now, it ran perfectly until the plugs got changed
the engine light does come on now as well.
This post has been edited by mrgignac: Jun 15, 2012 - 7:55 PM
post Jun 15, 2012 - 9:59 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
If the check engine lights on pull the codes that could very well be the source of atleast part of the issue. So you've got a miss fire ya say? pull the plug wires one at a time while it's running and if you pull one and it changes nothing you've atleast found the cylinder that is missing. I'd definitely pull those codes though.
post Jun 15, 2012 - 10:04 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Bosch Platinum could be your problem, try some plain copper Denso or NGK plugs.
post Jun 16, 2012 - 8:49 AM
Special_Edy
Joined Oct 29, '11
QUOTE (Bitter @ Jun 15, 2012 - 10:04 PM) *
The emmissions label under the hood should have the factory spark plug listed on it. It is usually on the underside of the hood near the latch.
Lo-Fi Version Time is now: September 4th, 2026 - 9:23 PM
