Jun 17, 2012 - 12:50 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
Ok so ive got a question.
Can bad aux wire cause that super annoying whining sound. I went through my system today an redone my ground an i know its big enough for my amp The ground an power are good for 650 an my amps only 250. so im figuring its gotta eather be the aux wires or the actual radio ground As long as i have the amp set for bass only the whine isnt there but since i have 4 subs it would be nice to turn on the vocals too -------------------- 95 gt coupe, v6 swap weekend toy
Jun 19, 2012 - 2:43 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
Are your rca inputs run alongside your power wire all the way to the back? They need to be on opposite sides of the car or you will get a whine. And yes I would try temporarily running new wires from the deck to the amp as they will definitely cause a whine
-------------------- ST205 Crew represent
![]() Challenge Accepted |
Jun 20, 2012 - 10:05 AM
You can purchase shielded wire if all else fails. Its got a foil sheathing that you ground to the vehicle chassis. Some of the EFI sensors have them
Jun 20, 2012 - 11:26 AM
My amps under my drivers seat.
The power wire is ran from the battery down the drivers side to the amp under the seat an the rcas are run from the center console to the amp -------------------- 95 gt coupe, v6 swap weekend toy
Jun 20, 2012 - 11:49 AM
If one of the aux wires is loosely connected, it can make the same buzzing. It's something that's easy to check and easy to fix.
Jun 20, 2012 - 12:05 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
The amp I use to have in my car hummed when I first put it in because I ran a straight 12v power lead to it from the battery (with a switch). I didn't leave it like that cause it wasn't that way in my other car so I actually used the antenna turn on wire and it stopped humming
Jun 20, 2012 - 1:29 PM
Ok well ill try a pick up a new set of rcas this weekend a if that doesnt work ill redo my remote wire an see what hapoens
Jun 20, 2012 - 2:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Are your rca inputs run alongside your power wire all the way to the back? They need to be on opposite sides of the car or you will get a whine. And yes I would try temporarily running new wires from the deck to the amp as they will definitely cause a whine Technically not true, unless he is feeding other higher spectrum speakers which will pick up such whine. Sub amps filter that out, unless he has the filter way way up. Mine are run together with no whine, and are not shielded. Most likely you have a bad ground, or your alt is causing the whine. This post has been edited by rave2n: Jun 20, 2012 - 2:57 PM |
Jun 20, 2012 - 3:41 PM
Could upgrading the grounds under the hood help
My grouund now is where the seat rail bolts to the floor And yes i sanded all the paint off -------------------- 95 gt coupe, v6 swap weekend toy
Jun 20, 2012 - 3:49 PM
Could upgrading the grounds under the hood help My grouund now is where the seat rail bolts to the floor And yes i sanded all the paint off Check the ground on the head unit, or make a new one all together for it. Also check to make sure connections to alt are secure. |
Jun 20, 2012 - 4:47 PM
Ok
Ill look at all of that this weekend too -------------------- 95 gt coupe, v6 swap weekend toy
Jun 20, 2012 - 6:39 PM
RCA wires are next to ground wires or you have a bad ground.
Jun 21, 2012 - 10:07 AM
Enthusiast ![]() ![]() ![]() Joined Sep 1, '09 From Marengo, IL Currently Offline Reputation: 0 (0%) |
You don't want to create a "ground loop". Ground all the sound stuff at one point on the body, that is usually the problem.
-------------------- ![]() 2000 GT-S 6 SPD... SOLD! |
Jun 21, 2012 - 10:23 AM
So i should ground the amp an radio in the same place
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:53 AM |
